1. Re: Adobe AIR, linux SIGSEGV
planetf1 Nov 9, 2009 2:08 AM (in response to planetf1)Note the incorrect title (but no way to edit....). Browser history got the better of me (I enjoy photography!)
EDIT: I was able to update this response not the original despite noting the error immediately. What gives?
2. Re: Adobe AIR, linux SIGSEGV
belegdol Nov 9, 2009 3:43 PM (in response to planetf1)It seems to me that this is rather an Adobe Air issue, since I'm experiencing a segfault when installing ipla lite. This is on pre-release Fedora 12 x86_64. Everything worked like charm in Fedora 11 x86_64 prior to the upgrade. I tried re-installing Adobe Air, but to no avail. I have attached the crash log the program produces.
1110_0026_nc37nH.bz2 6.1 K
3. Re: Adobe AIR, linux SIGSEGV
planetf1 Nov 9, 2009 3:53 PM (in response to belegdol)I'm running 32 bit x86 -- it was working fine until last week. Possibly new gtk etc libsm but hard to know what.
4. Re: Adobe AIR, linux SIGSEGV
Robert Christensen Nov 9, 2009 4:17 PM (in response to planetf1)We are currently looking into this issue and will report back once we have more information. Thank you for letting us know.
- Rob
Adobe AIR Team
5. Re: Adobe AIR, linux SIGSEGV
planetf1 Nov 9, 2009 4:34 PM (in response to Robert Christensen)Thanks,
I did also try using "strace" to see what AIR was up to when it fails. Looks as if it might relate to some encryption settings in /etc/opt/Adobe/certificates/crypt//config.xml
Also looking at the core file I can see (an excerpt)
/opt/Adobe AIR/Versions/1.0/libCore.so(+0x2ea3ba) [0xfd03ba]
/opt/Adobe AIR/Versions/1.0/libCore.so(+0x2de565) [0xfc4565]
[0xca940c]
/usr/lib/libxml2.so.2(xmlHasProp+0x27) [0x3b8cae7]
/usr/lib/libxml2.so.2(xmlGetProp+0x19) [0x3b8d5f9]
/usr/lib/libadobecertstore.so(+0xf345) [0x5aa345]
/usr/lib/libadobecertstore.so(+0xf7db) [0x5aa7db]
/usr/lib/libadobecertstore.so(AUCS_GetCertificateList+0x29) [0x5aa727]
/opt/Adobe AIR/Versions/1.0/libCore.so(+0x4a937c) [0x118f37c]
but there's so much going on that's just a guess... can share data if required. -
6. Re: Auto focus, iso
chopr Nov 10, 2009 3:04 AM (in response to planetf1)Can you try the following if possible:
1. Uninstall AIR
2. mv /etc/opt/Adobe/certificates/crypt /etc/opt/Adobe/certificates/crypt_bkp (you need to be root for this)
3. Install AIRNow try installing Tweetdeck again.
7. Re: Auto focus, iso
planetf1 Nov 10, 2009 3:20 AM (in response to chopr)That worked!
Adobe AIR Application Installer.swf libCore.so
sh-4.0# ./Adobe\ AIR\ Application\ Installer ~/Download/TweetDeck_0_31.3.air
I/O warning : failed to load external entity "/etc/opt/Adobe/certificates/crypt//config.xml"
Unable to parse Document: /etc/opt/Adobe/certificates/crypt//config.xml.
So there's obviously some complaining about certificates, but tweetdeck is running.
Thanks for the quick helpful answer. Does this mean there's some breakage in the certificate checking (possibly after an update) or is this just cached/temporary data that needed to be cleared out?
Nigel.
8. Re: Auto focus, iso
belegdol Nov 10, 2009 3:20 AM (in response to chopr)It worked - i.e. both the installation, as well as the installed application itself. Adobe Air complained about missing files, though, but I guess that's expected:
$ "/usr/bin/Adobe AIR Application Installer"
9. Re: Auto focus, iso
chopr Nov 10, 2009 3:34 AM (in response to belegdol)Did you Uninstall AIR runtime before moving the folder ?
10. Re: Auto focus, iso
belegdol Nov 10, 2009 3:36 AM (in response to chopr)Yes, I did. But, last time I checked, uninstalling Adobe Air via the desktop entry only removes adobeair1.0 RPM, the adobe-certs one stays intact.
11. Re: Auto focus, iso
chopr Nov 10, 2009 3:41 AM (in response to belegdol)I guess you won't see this error if you uninstall adobe-certs and then reinstall Adobe AIR runtime.
12. Re: Auto focus, iso
belegdol Nov 10, 2009 3:48 AM (in response to chopr)Unfortunately, that got me back to square one: Adobe Air segfaults again.
1110_1246_5MAGqy.bz2 6.0 K
13. Re: Auto focus, iso
chopr Nov 11, 2009 8:39 PM (in response to belegdol)Could you please send me your config.xml (found here: /etc/opt/Adobe/certificates/crypt/config.xml) to priyank.choudhury [at] adobe [dot] com
This contains the hashes of the certificates that AIR installed on your machine.
Thanks.
14. Re: Auto focus, iso
belegdol Nov 17, 2009 8:11 AM (in response to chopr)Did you get my email? If so, have you been able to figure anything out? Thanks.
Also, I installed the 2.0 beta from labs rpm (after removing both older rpms) and everything works fine now.
Message was edited by: belegdol added labs beta note
15. Re: Adobe AIR, linux SIGSEGV
belegdol Dec 19, 2009 2:22 AM (in response to belegdol)The issue is still present with 1.5.3. The crypt directory rename still works the problem around.
1219_1119_xZjdMo.bz2 5.7 K
16. Re: Auto focus, iso
omegabsd Jan 31, 2010 2:23 PM (in response to planetf1)After playing with aucm, I noticed that adding new certs added the <UserPreferences> tags when adding a new cert. The config.xml from the adobe-certs package did not have this tag. I added it to each certificate object in config.xml, for example:
<certificate trustAnchor="true" trusted="true" sslServerAuth="true" codeSign="true" >
<UserPreferences/>
<LastUpdatedBy trustAnchor="adobe" codeSign="adobe" sslServerAuth="adobe" trusted="adobe"/>
<subjectHash>2afc57aa.0</subjectHash>
<publicKeyHash>46tUTICh21ZDt5FKy/OCehNcCKt=</publicKeyHash>
</certificate>That fixed all the SIGSEGV dumps. (And keeps you from getting all the unknown/unverified cert messages during application installation you get when you just rename the crypt directory.)
17. Re: Auto focus, iso
SalChicago Apr 22, 2010 2:41 PM (in response to omegabsd)related to this:
I get the same issue, but that's because I am using the SDK adl tool to run the application.
So all I did was create a folder under /opt/AIR-apps/ for the application and I unziped the *.air file into a folder of its own.
Then I used the command line to run it and I get stuck on this error.
Should I do something extra to get these certificates 'installed'?
my /etc/opt/ folder is completely empty.
// Sal
18. Re: Auto focus, iso
omegabsd Apr 22, 2010 3:34 PM (in response to SalChicago)They get installed as part of the adobe-certs package, which is distributed with the air package.
19. Re: Auto focus, iso
SalChicago Apr 22, 2010 3:48 PM (in response to omegabsd)I must be missing something.
You mean when one runs the application ... It should install these certs?
I looked for something with 'cert' in the qsin/ folder an found nothing. Is it because I am using this on Gentoo rather then Ubuntu or Fedora?
Should I have ran some other script after unpacking the SDK and putting it on /opt/AIR-SDK/ ? Sounds to me like that is what I missed?
Bottom line: What do I do to get these certs installed on that folder ?
Any help will be greatly appreciated!
Thank you!
20. Re: Auto focus, iso
chopr Apr 23, 2010 12:19 AM (in response to SalChicago)For working with Certificates you would need to install AIR runtime on your machine, SDK is not enough. Please install the AIR runtime from: http://get.adobe.com/air/
21. Re: Auto focus, iso
SalChicago Apr 23, 2010 8:15 AM (in response to chopr)I did try that, but because I'm using Sabayon (a gentoo derivative) It tells me that the Installer is not supported in Non rpm or debian bases distros.
So that's why I resorted to using the SDK. Which I can get to work for other Air apps, but not mine: qsin. This works fine in Fedora and Ubuntu.
So is there a work-around to the runtime in Gentoo/Sabayon? Any help will be appreciated.
// Sal
