Hi Helper,
I am using both amf &
amfsecure
I defined my servlet-config.xml properly and also added the custom channel in my AC
var ch1:SecureAMFChannel = new SecureAMFChannel("my-secure-amf", "https://xxxxxxx/messagebroker/amfsecure");
var channelSet:ChannelSet = new ChannelSet();
channelSet.addChannel(ch1);
then i set this channel set to my service.
When i run the application and try to access the remote service method nothing happens and after a min or so exception comes that not able to make the connection.
The error:
channelSet = (mx.messaging::ChannelSet)#6
clientId = (null)
connected = false
defaultHeaders = (null)
destination = "RFWFlexTreeTableDataService"
id = "0E18136A-CC9E-0C3A-7A8D-D4988264426C"
reconnectAttempts = 0
reconnectInterval = 0
requestTimeout = -1
subtopic = ""
connected = false
connectTimeout = -1
enableSmallMessages = true
endpoint = "https://xxxx/messagebroker/amfsecure"
failoverURIs = (Array)#11
id = "my-secure-amf"
mpiEnabled = false
netConnection = (flash.net::NetConnection)#12
client = (mx.messaging.channels::SecureAMFChannel)#4
connected = false
objectEncoding = 3
proxyType = "none"
uri = "https://xxxx/messagebroker/amfsecure"
piggybackingEnabled = false
polling = false
pollingEnabled = false
pollingInterval = 3000
protocol = "https"
reconnecting = false
recordMessageSizes = false
recordMessageTimes = false
When trying to run https://xxxx/messagebroker/amfsecure to test the messagebroker, it works fine.
In addition,I can use normal AMFChannel and it worked fine for me to access the remote services.
Only issue I am facing is with SecureAMFChannel.
What am I doing wrong?
Does using SSL related to this problem.
Please please advise
Jo
Total Likes
I resolved the issue
The missing part was adding flex-tomcat-common.jar in lib directory
and making sure we use amfsecure
Total Likes
