I have a project with some Conditional Build Expression artifacts that I simply cannot get rid of.
For example, I have created two Conditional Build Expressions:
Internal OR Foo1
Foo1 OR Foo2
It has been determined that the second expression is the one we want. But, the first one still shows up as an option in the SSL. Furthermore, when I view a page, the first expression clutters up my list of possible Conditional Build Expressions.
How can I lose a Conditional Build Expression? I have quite a few possible arrangements, and I don't want to confuse other authors by having too many choices (especially with similar names).
Kevin
Hi Kevin.
I think you have to do this by manually editing the project's .pss file (projectname.pss). If you take a backup of this file and open it in Notepad you'll find a [Global Build Tag Expressions] section and hopefully in there will be your "Internal OR Foo1" expression preceded with a date/time stamp. If you remove this line it should no longer appear in your project.
Hi Kevin.
Backup the project first but I think you can just trash the PSS.
Follow me @petergrainge
