I am trying to generate Help file out of word document through robohelp 7.0. The problem is the topics do not get separated as per headings. Like say for example, the heading style ( outlining level ) goes like this:
Level 1
Level 2
Level 3
Level 1
Level 2
Level 3..so on ..
When I import the document, I check options to create different topics based on Headings, I check heading 1 , 2 and 3. However, after generating the final output, the first 3 levels in bold are organised correctly, however, the next level 1 Topic and topic levels thereafter are not separated into separate pages, it continues along with the Topic marked level 3 as a continous section.
Has anybody encountered this problem before. Or do i have to bookmark my topics ? Is there any setting that I need to do in Word or the tool ?
I am not sure about this, looking forward to more inputs on this.
Pallavi
Hi Pallavi.
Do you have your styles mapped correctly? Check out this link.
I think I have mapped them corectly. By Style u mean the Heading and outline right? If yes, I have done it..
That is right. Your word document has styles associated with it and your RoboHelp project has a style sheet that controls the way in which styles are created. You need to map the styles so that they appear the way you want.
I have set the styles within word. Through Robo Help, do I set it through the default css which gets created? Say for paragraph, Map Heading 1 to Heading 1 and so on.
Pallavi
Thats it.
Hey Thanks a ton for the inputs. I should get it right this time.
