Ok I've got my document all made and nice and pretty, I use it to enter information and use the selection box to make visible the fields I need for each card. Then I save it and try to open it and get the following error popup message.
Invalid node type: selectionbox
Message limit exceeded. Remaining 10 errors not reported.
So I click ok on the error box. It opens the file with adobe reader like it's supposed to and then immediately I get the "Adobe reader has stopped working, windows can check online for a solution to the problem" and I get the two choices that both involve closing the program.
I got this once before and after about a half hour of fiddling with the original livecycle file it stopped doing it. I have no idea what I did to make it start or stop doing it and I'm not sure I even did do anything to cause it.
Has anyone else come across this problem? Does anyone know what I need to do to fix it?
I've included the file I'm having issues with.
Aaron
Total Likes
Hi Aaron,
I cant replicate your problem. What I did notice though, is when I make a selection on almost every selection box, I get the following error:
'cardtwo.TextField1 has no properties'. The error is coming from the following piece of code in the change event: 'cardtwo.TextField1.caption.text.value = (this.rawValue);'
I dont see a TextField1 in the cardtwo subform so I suspect that this field has been renamed and / or moved since that bit of code was added. Perhaps that would be a good place to start and could very possibly be the cause of your problem.
Dallas
Total Likes
Thanks for the tip, I'll try it out tonight and see whether that fixes my problem. Either way it was definitely a lost bit of code that isn't necesary any longer. I had deleted it from one of the selection boxs but forgot the other 3. Hopefully this fixes my issue.
Aaron
Total Likes
