RDS connection fails
Guest
Sep 17, 2009 Sep 17, 2009
Hey,
I have setup ColdFusion and ColdFusion Builder on a development workstation.  Now I'm trying to get debugging to work however I'm having heck of a time trying to get RDS to work.  I have made sure the RDS is not commented out in web.xml and retyped the RDS password.  I'm using the following:
Host Name: localhost
Port: 8500
Context Root: C:\ColdFusion8\wwwroot\
Username:
Password: ***
Any words of wisdom or pointers in the right direction?
Kasia
Builder
2.8K
Deleted User
Is your server running?
Can you access the Admin page successfully?
Did you try adding it through the server manager?
-Bhakti
Guest
At this point I'm trying anything
SettingsResults
Description: localhost
Port Number: 5005
Context Root: /
User Name:
Password: ****
Unable to contact the RDS Server "localhost."
Premature EOF encountered
Changed to:
Context Root: /tests/fusebox_catclub
null
Guest
-Bhakti
Guest
Sep 18, 2009 Sep 18, 2009
Thanks for replying Bhakti!
You have pointed me to the right direction.  I'm new to ColdFusion (transferring from PHP and Java) and going to Server Manager page was the answer.  However that opened another box of warms, since I'm running IIS 5.1 which apparently doesn't mix well with RDS.  It a good excuse to change to server 2003 though.
Thanks again.
Nov 11, 2009 Nov 11, 2009
hi,
   So you mean IIS and RDS has some issue? because currently I have a problem on RDS and IIS.
And there is an error (A connection to the RDS Server could not be established because the webserver was unreachable).
Even if I enable the RDS in Coldfusion. And use Port 80.
Please advise..
thanks.
Guest
Check your line debugger settings.  Make sure that "Allow Line Debugging" is on (by default it's turned off); if you're using CF9 you will be able start/restart the debugger server on the same page, if you're on CF8 you might have to do a restart through services.
My settings are:
DEBUGGER SETTINGS:
Allow Line debugging - ON
Debugger Port: 5005
Maximum Simultaneous Debugging Sessions: 5
ECLIPSE SERVER SETTINGS:
Servername: localhost
Application Server: Jrun
WebServer Port: 80
RDS User Name: admin
RDS Password: ******
Another IMPORTANT factor is... make sure you are running eclipse 3.4.2 not the latest 3.5.1 which is not supported by the ColdFusion Builder installed as eclipse plugin.
Hope that helps,
Kasia
Documentation
