cfexcute
Participant ,
Aug 05, 2008 Aug 05, 2008
The following doesnt copy the data from csv into db table... why? Any help appreciated...My CF and SQL server are on my local machine.
Advanced techniques
1.4K
Advocate ,
Where is the file "scorecard_30_import_Saves" located?
Advocate ,
Did you encounter any errors?... Have you checked the application logs?...
Participant ,
Aug 06, 2008 Aug 06, 2008
The new error is :
DTSRun: Loading... Error: -2147217900 (80040E14); Provider Error: 14262 (37B6) Error string: The specified DTS Package ('Name = 'scorecard_30_import_Saves'; ID.VersionID = {[not specified]}.{[not specified]}') does not exist. Error source: Microsoft OLE DB Provider for SQL Server Help file: Help context: 0
Advocate ,
So I ask again:
This line of code:
<cfloop index="i" list="Saves">
loops over a list. However, if "Saves" is a variable containing a list, you need to enclose it in pound signs:
<cfloop index="i" list="#Saves#">
Without the pound signs, ColdFusion thinks you're passing the string "Saves" in as the list, which, as a comma-delimited list, only contains one element, "Saves".
Participant ,
<cfset saves = "Saves">
<cfloop index="i" list="#saves#">
it is saved on my document folder as 'scorecard_30_import_saves'
Still same error...help
Advocate ,
Give it a full path to that file. You also need to be sure that the user that ColdFusion is running under can see that file.
Participant ,
Still same error:
<cfscript>
targ = structNew();
targ.Exe = "c:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtsrun.exe";
targ.server = "NYCWSITSSALEEM";
targ.verBase= "30";
</cfscript>
<cfexecute name = "#targ.Exe#"
arguments = "/S #targ.server# /N C:/Documents and Settings/vozturk/My Documents/scorecard_30_import_saves.dtsx /U cf_user /P 1 /A DateToUse:8=#DateFormat(now(), 'MM/DD/YYYY')#"
timeOut = "300"><!--- 5 minutes --->
</cfexecute>
</cfloop>
Advocate ,
What user is ColdFusion running as? Can that user see that file?
Participant ,
cf_user is a SQL 05 admin user....
Advocate ,
....right....
but can that user access the file?
Participant ,
Aug 07, 2008 Aug 07, 2008
cf_user doesnt exist on windows environment, it is a SQL 05 power user. As I mention, CF and SQL 05 are located on my local machine...
I still dont understand how this thing will work !
I looked at the security of that dtsx file ...That user doesnt exist in the list
Advocate ,
OK, I guess I need to make myself clearer.
When Coldfusion runs a command via cfexecute, it runs as the user that the Coldfusion service is running as.
To find that out, open up Task Manager and find the coldfusion process. What username is that process running as? Hint: it can't be a SQL Server user.
Participant ,
I already checked that.. it runs on 'local system account'
Advocate ,
The error you're getting is still this?
DTSRun: Loading... Error: -2147217900 (80040E14); Provider Error: 14262 (37B6) Error string: The specified DTS Package ('Name = 'C:/Documents and Settings/vozturk/My Documents/scorecard_30_import_Saves'; ID.VersionID = {[not specified]}.{[not specified]}') does not exist. Error source: Microsoft OLE DB Provider for SQL Server Help file: Help context: 0
Since there's a space in the path to that file, you might need to put quotes around it:
<cfscript>
targ = structNew();
targ.verBase= "30";
</cfscript>
arguments = "/S #targ.server# /N 'C:/Documents and Settings/vozturk/My Documents/scorecard_30_import_saves.dtsx' /U cf_user /P 1 /A DateToUse:8=#DateFormat(now(), 'MM/DD/YYYY')#"
</cfexecute>
</cfloop>
Can you run this command from a dos prompt?
C:\Program Files\Microsoft SQL Server\80\Tools\Binn\dtsrun.exe /S NYCWSITSSALEEM /N 'C:/Documents and Settings/vozturk/My Documents/scorecard_30_import_saves.dtsx' /U cf_user /P 1 /A DateToUse:8=08/07/2008
Participant ,
The run results :
Participant ,
Sorry this is run results:
Error string: The specified DTS Package ('Name = ''C:/Documents and Settings
/vozturk/My Documents/scorecard_30_import_saves.dtsx''; ID.VersionID = {[not sp
Help file:
Help context: 0
Advocate ,
This will take forever if I have to ask the same question multiple times:
Can you run this command from a DOS prompt?
What is the output of running that command, from the DOS prompt? If it's the same, DTS package does not exist, are you positive you are using the correct filename?
Participant ,
Aug 08, 2008 Aug 08, 2008
'scorecard_30_import_saves.dtsx' file name and location is same as above... Yes I am getting the error I am posting...
Help file:
Help context: 0
Advocate ,
Is that the output of running the command from the DOS prompt?
Participant ,
YES
Advocate ,
Well then, it has nothing to do with Coldfusion. You need to get that command working in the DOS prompt first. Then, and only then (because you know it's working), you can move it into CF.
A quick google search yields:
http://forums.microsoft.com/msdn/ShowPost.aspx?PostID=2947781&SiteID=1
http://support.microsoft.com/kb/308801
http://www.mydatabasesupport.com/forums/sqlserver-faq/228365-help-dtsrun-dts-package.html
http://support.microsoft.com/kb/299354
http://www.dbforums.com/showthread.php?t=1622934
http://www.developmentnow.com/g/103_2006_9_0_0_827238/DTSrun-gives-Package-does-not-exist-error.htm
I'm not sure what will fix your problem at this point, but based on those links, you might want to just try changing /N to /F and seeing if that takes care of it.
Participant ,
Yes sir
Participant ,
None of the posted links help.. Any way thank you for the help
Documentation
