Array? List? Collection? Loop?
Participant ,
Aug 12, 2008 Aug 12, 2008
I have a form that uses cfselect where the user can select multiple items. I am sending the category id to the next page. When I do a dump of the form for #form.category# I get the correct items in a "list" as in " 184, 450, 38, 233". On the next page I need to select the category names for all the id's the user selects.(They can select 1-400) This is throwing me off on how to set up the item in order to even start the query.
I tried stripping out individual items using this
<cfset firstcat = Right(form.category, Len(trim(form.category))- Find(",",form.category,1))>
That worked for the first one but isn't their a better way to do this dynamically since I'm not going to know how many categories they select. My deliminater is the comma
Then how do I set the query up in order to select one or more categories?
Select * from cat_area where area_id = '#trim(firstcat)#' - this obviously only works for the 1st category.
I've been trying arrays and lists but I think I can't see the forest for the trees anymore. Any help would be greatly appreciated. Thanks
Advanced techniques
575
Valorous Hero ,
It is much simpler than you are thinking. You can use the sql keyword IN to search for multiple id values.
SELECT Columns
FROM cat_area
WHERE area_id IN
<cfqueryparam value="#trim(form.category)#" list="true" cfsqltype="(whatever your data type is)">
Watch out for spaces in between list elements. It can throw off searches on varchar fields. Though your fields look numeric so that may not apply here.
Participant ,
It didn't like the work "IN" so I tried "where area_id like" which seems like it's moving in the write direction only the problem is with the commas. I'm getting this error message:
Error Executing Database Query.
[Macromedia][Sybase JDBC Driver][Sybase]Incorrect syntax near ','.
The error message for "In" is incorrect syntax near "where"
Valorous Hero ,
No, you cannot use LIKE. It will only compare a value against a single pattern.
Sybase supports the keyword IN so I suspect there is a syntax error. Can you post the exact query code?
Participant ,
Aug 14, 2008 Aug 14, 2008
<cfquery datasource="swp" name="getcategory">
select * from cat_area
WHERE area_id in #form.category#
<cfqueryparam value="#trim(form.category)#" list="true" cfsqltype="Char">
</cfquery>
The error is Error Executing Database Query.
[Macromedia][Sybase JDBC Driver][Sybase]Incorrect syntax near '467'.
and the number 467 is the first area_id in the list.
In the error message it shows the SQL as select * from cat_area WHERE area_id in 467 ,390 ,29 ,92 ,349 ( (param 1) , (param 2) , (param 3) , (param 4) , (param 5) )
so it appears to be bombing on the comma.
You don't see something a but redundant and confusing in that code?
Try it with just the *one* form.category inside the <cfqueryparam...> tag.
Participant ,
That did it - thank you - that was a homer simpson moment - doh!
Valorous Hero ,
Also "char" is not a valid cfsqltype type. It should be something like cf_sql_char, cf_sql_varchar, etcetera. The type corresponds to the column data type.
http://livedocs.adobe.com/coldfusion/7/htmldocs/00000317.htm
Documentation
