Hello all,
I've been teaching myself how to use XML rules by going through some of the samples scripts in the Scripting Guide. Most of them work very well, but a few of them (such as XMLRulesApplyFormatting.jsx) produce the following error message:
Can anyone tell me what's going wrong?
I've been using the "short cut" script (XMLRulesExampleSetup.jsx) to set up the example document rather than going through the bother of importing XML manually each time.
Thanks in advance -- Jeremy
Actually, all of the sample scripts seem to work fine with CS3, so I'm guessing the problem has something to do with changes from CS3 to CS4. I downloaded a fresh set of scripts for CS4, so I'm definitely using the right ones.
