1 Reply Latest reply: Nov 25, 2009 8:59 AM by JSS1138 RSS
    Replace menu & reverse fields
    Geoff Vane Community Member
      It's nasty I can't replace slightly modified menu's. Have to do the entire routing again...
      There one big feature that drives me crazy because it isn't there. A field reverse option by placing everything one pixel layer lower. (no swap please)
      Just bake a DVD and then find out that some footage has the fields reversed! It is terrible.
      Don't say: Just make correct footage outside Encore. Ofcourse I should do that, but for some mysterious reason, my projects have a 50% chance of field reversal. I can't go on without a quick field reverse option. I think it has something to do with my Axio hardware and codec, but that's what I have.
        • 1. Re: Replace menu & reverse fields
          JSS1138 Community Member
          If you do the menus in a certain way, you can.  For example, using Photoshop and/or a DL'd AE comp.
          I would argue that this is beyond the scope of an authoring application, and should not be added.  If the Matrox is messing things up, lose it.  (That's what I and many other did.)
