I have a folder in my project that has a ton of files in it that I will never need to edit or search or access in anyway through CF Builder. I believe this folder is the culprit for the 10 minutes it takes CF Builder to start up. The only option I can find to remove the folder from the project is "Delete", but "Delete" will delete the files from the file system. I need the files for my app to run, so I can't delete them. I just don't want them to be a part of the workspace. Does anyone know how to remove a folder from a project with out actually deleting the folder/files from the file system?
Donnie Carvajal
Donnie,
I don't know of a simple way to remove the folder from your project (I can think of some "hacky" ways that you'd probably not like). But as far as your 10 minute startup time...have you disabled "Refresh on Startup"? Preferences->General->Startup and Shutdown. If not, this can really slowdown your startup time. But I think this also means that you might have missing files if they've been added since the last time you opened CFB.
Sounds like a good feature to add to CFB to me. Maybe raise an enhancement request: http://cfbugs.adobe.com/bugreport/flexbugui/cfbugtracker/main.html
I'd vote for it.
Adam
Here's what I've done to stop the massive images folder from the site I'm working on appearing in CFB (and slowing everything down).
I moved the images folder completely out of my project root.
I then made a mapping in the jrun-web.xml file so the browser still sees the folder there.
e.g.
If my project is in C:\webroot\project and I browse to http://localhost/project to view it.
I move the images folder from C:\webroot\project\images to C:\<other_location>\project_images
Then in <CF_ROOT>\wwwroot\WEB-INF\jrun-web.xml I add:
<virtual-mapping>
<resource-path>/project/images</resource-path>
<system-path>C:\<other_location>\project_images</system-path>
</virtual-mapping>
Restart CF and now I can browse to http://localhost/project/images but the folder itself is not part of the CFB project.
The location of jrun-web.xml is for if you are using CF standalone. Not sure where it is for multiple sites in JRun configuration.
Also this is my own local dev machine. If you are doing this on a shared server, it probably isn't practical.
Hope that is some help,
Andy
Hi Andy,
Thanks for the advice, but unfortunately moving the folders from this app would take more time and cost more than it's worth to change just so an IDE that is missing an obvious feature can have a work around.
Donnie
Have you raised an issue in the bug base as per my suggestion? That's the easiest way to get these things sorted out...
Adam
Adam,
I did add this issue the to bug report for CF Builder. I also looked on the Eclipse forums and it appears that this issue is also in Eclipse, so I don't know if Adobe can fix it.
Donnie
What's the bug ref number? I cannot see the issue in the bug tracker? It's always good to report back with the ref number or a direct link to it to encourage other people to vote for it.
Adam
Here is a link to the bug:
http://cfbugs.adobe.com/bugreport/flexbugui/cfbugtracker/main.html#bugId=80700
Cheers mate: I've voted.
Adam
I just received an email from the Adobe ColdFusion Team indicating that this bug has been verified and it has been targetted for CF Builder 2.0., Alpha 1
Thank goodness this feature will be added! The ability to remove certain files/folders from a resource folder in a project would make my life sooooooooo much easier!
It would also be nice if they let you add a single file from a different directory than where the main project folder resides.
Like if you go File > New > File > Advanced > Link to file in the file system?
Adam
