Since updating to AR9 when checking for updates an "Adobe Reader Updater" window appears indicating that "proxy authentication is required" and asking for username and password, which on adding the (full) name and password for our proxy redisplays the window.
On cancelling you get the error 1400.
What / Whose proxy is this ? How do you set it ?
In your Internet Explorer menu select
Tools->Internet Options->Connections Tab->LAN settings button
In the Local Area Network (LAN) Settings dialog uncheck Proxy server
It may take a few minutes for your changes to take effect - do not start "Check for updates" too soon.
Sorry, that does not solve the problem.
Additional information:
This is a PC running Windowes XP SP3 connected through a Small Business Server 2003 R2 using ISA 2004.
How does it not solve your problem - have you unchecked the Proxy Server option, or was it not checked at all?
I unticked the "use a proxy server . . " option. I'm using IE8
I checked the issue out on a new PC which I'm installing software:
I initially installed AR 9.1 and then updated this using the "check for updates" option. This updated AR to version 9.2.0.
I then clicked on "check for updates" again; the window "Adobe Reader Updater" was displayed showing "Checking for Updates . . "; a second window "Adobe Reader Updater" was then displayed asking for "Proxy Authentication is required".
Whatever combination of user/password was used this window was redisplayed and on cancelling => the original window displayed "cannot establish a connection. Please try again later" "Error: 1400"
This to my knowledge has occurred after updating to 9.2 on a number of PCs. I also tried it on out test Windows 7 PC and a similar issue arose.
Thanks for your help
Brian
Can you also check within Adobe Reader - Edit | Preferences | Internet | Internet Settings | tab Connections | LAN Settings. This is where the Updater takes its information from (same as Internet Explorer).
I unchecked "use a proxy server . . " through Adobe preferences and this still did not allow updates.
Something has been changed between 9.1 and 9.2 !?
If you unchecked it again (the mechanism is the same as in Internet Explorer), then it wasn't accepted the first time. And obviously it hasn't been accepted this time either. You did click Apply and/or OK after unchecking?
Whether the "Proxy Server" setting is checked or unchecked AR 9.2 will not "Check for Updates".
There is a fundamental error introduced in 9.2 which affects domain based PCs.
On non domain based PCs the AR9.2 will check for Updates irrespective of the Proxy sewtting.
Adobe could easily check this out - so please check !
The Adobe Updater is attempting to bypass the standard ISA client authentication by initiating a connection as an Anonymous User rather than allowing the client to connect as a domain member. Why this would be designed this way is another question.
Do not change the Proxy settings on your clients, it will have no effect on the Adobe Updater and may disable other functions - you know, the ones that were properly written.
You will need to create a new ISA rule allowing all users in the protected network access to either a created URL set or Domain set as shown below, whichever you prefer.
URL set --
We have run into the same problem here. And no amount of checking, or unchecking, or changing the Internet settings solves the problem. We did some testing and found that this does not affect machines running Windows 2003, but does affect XP. It also was not an issue before updating to version 9.2. We did a packet capture of the data after the update and it shows our proxy server answering that it needs credentials passed to it. We then tested on an XP box with 9.0 installed and you could access the updates fine. Update it to 9.2 and it quits working. Install 9.2 on its own and it still doesn't work. As far as we can tell, 9.2 is not sending the credentials along with its request no matter what you put in the settings.
Domain set --
adobe.com
*.adobe.com
URL set --
Of course, doing that totally undermines the reason for using a proxy server in the first place. I think we will just wait until the next update comes along to see if that fixes the authentication problem.
Well, I don't see the level of certainty you envision as being a matter "of course" for all situations. Whether or not the rules "totally," or even minimally, undermine the proxy's purpose would depend on its intended role, how you implement this (or any) rule, and what other security/isolation measures you have in place. Each administrator would have to make his or her own determination.
While I don't see how granting access through a newly implemented rule is any more of a hazard than your preferred utilization of access already granted through existing rule; I can suggest that use of the URL set would certainly grant tighter privileges than would use of the Domain set, which is why I offered both.
Again, YMMV.
Thanks for the info.
Unfortunately I have been off site this week and have just returned back. I will check out the workaround! over the weekend.
Can you please tell me if this info was made available by adobe and if so where I might find it.
Thanks again for your help.
Brian
Brian,
You are quite welcome.
Let us know how it works.
> ...tell me if this info was made available by adobe...
Not that I am aware of.
We would like to invite you to our private Reader 9.2 Updater prerelease to see if it solves your problem.
Tupper Snook
Group Program Manager
Acrobat Team
I'm having the same problem here ... identical to what Eur0star1 is having.
A workaround would be nice.
Chris.
Can you send Chris an invitation for the 9.2 Beta please?
Chris, can you provide us with a direct email address and company name please?
-Tupper
It's the same thing on a Mac, Adobe Updater asks for authentication for the proxy. But ignores it when it gets it, and keeps asking.
...and this affects all adobe applications on my Mac, not just adobe reader, so my CS4 Master Collection cannot get any updates
Tried to install a new version of Reader, to access downloaded IRS forms. Followed all prompts until I got to a popup asking for my password. No such password is available, and so installation was aborted. This sounds like it might be related to authentifications others report here. Any simple fix?
We were able to fix Eur0star1 problem with proxy authentication for Acrobat and Reader 9.2 on Windows in the Beta program.
Unfortunately we do not have a solution with proxy authentication for MCHeath on the Macintosh for Acrobat and Reader.
We need more info from j_gurley to figure out your issue. Did you try downloading 9.3 version of Reader from http://get.adobe.com/reader/otherversions/ ? Are you on Mac or Windows? Are you Administrator or Standard user?
-Tupper
Seems that the problem lies in the Enhanced Security feature under Security (Enhanced). I turned it off under preferences and was able to install the update for Acrobat Reader 9.2/9.3. Previously, I had been receiving a failed to install error with error code 1400. One of the errors stated that it was unable to access a local file under my documents. I turned the settings back to use Enhanced Security features after the successful install.
Message was edited by: smackrobat
