I've got to fields on called supplier and the second one called product.
Both fileds can be populated form the database.
However. If the first field is selected ( Supplier) how
can i have the secon field ( product) automatically populated with only
those products applicable form the choosen supplier.
And the other way around.
The script i'm having is below.
<cfquery name="rs_supplier" datasource="Reach">
SELECT distinct "Supplier"
FROM ProdSupplier
ORDER BY Supplier ASC
</cfquery>
<cfquery name="rs_ProdFam" datasource="Reach">
SELECT distinct "ProdFam"
FROM ProdSupplier
ORDER BY ProdFam ASC
</cfquery>
<html>
<head>
</style></head>
<body>
<form name="form1" method="post" action="report1.cfm?">
<p> </p>
<table width="89%" border="0">
<tr>
<td height="29"> </td>
<td><span class="style1">REACH Documents </span></td>
<td> </td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
<tr>
<td height="29">Supplier</td>
<td><select name="Supplier" size="1" >
<cfoutput query="rs_supplier">
<option value="#rs_supplier.Supplier#"> #rs_supplier.Supplier#</option>
</cfoutput>
</select></td>
<td> </td>
</tr>
<tr>
<td height="29">Product Family </td>
<td><select name="ProdFam" size="1" id="ProdFam" >
<cfoutput query="rs_ProdFam">
<option value="#rs_ProdFam.ProdFam#"> #rs_ProdFam.ProdFam#</option>
</cfoutput>
</select></td>
<td> </td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
<tr>
What you are attempting is often called related selects. There is more than one way to do it. Here is an example of one of those methods. http://www.pathcom.com/~bracuk/code/RelatedSelects.htm
