I am using CFImage to generate price tags that my customer will print out and then display in their store. This allows them to have price tags that match the online store prices.
Currently, generating a price tag drives the server usage up to about 50% and it takes about 5 seconds to generate each price tag. I see this because I can see the jrun.exe process in the Task Manager. Does anyone have an idea of what is normal for performance when using CFImage? Any ideas about how to optimize the code so that it takes less CPU or completes more quickly? We've had numerous problems in the past when the jrun.exe was already high and the client selected about 5 tickets to be generated: this would cause the jrun.exe to max at 99% and to just hang.
Thanks for your help.
Olivier
Is it definitely the <cfimage> line that is taking all the time, or is it the rest of the logic on the template? Have you isolated it to the <cfimage> tag in particular?
Adam
The last time I looked the <cfimage> tag generates temporary images down under the JRun root directory. You might want to make sure you are not having disk I/O issues or size issues on the drives JRun is on. You might also want to demo the imageCR3 tag from Efflare as I personally think it does a better job.
