Hello,
I use RH 7 on Windows XP, and generate my help project using WebHelp.
The Search and Index functions work perfectly fine in the generated help project on my hard drive, but when the project is deployed to our Web server for user acceptance testing, these functions don't work.
For both functions, the "Done, but with errors on page" or "Error on page" message displays in the bottom left-hand corner of the browser window; when I click the icon (exclamation point in a yellow triangle), an error message displays with the following details:
Line: 688
Char: 7
Error: 'aTopics[...].sTopicTitle' is null or not an object
Code: 0
URL: http://<I removed this part of the path for security purposes>/webhelp/whfbody.htm
I've attached a PDF that includes screen shots comparing how these functions work on my hard drive and on the Web server (for security purposes, I crudely blocked out any company references in the URLs in the screen shots).
Does anyone have an idea off the top of their head as to what might be preventing the Index and Search functions from working? Perhaps this is due to a configuration or security setting on our Web server or something - this entire process is new to me, so I have no idea how to resolve this.
Thanks in advance!
Matt
Are you certain that all the WebHelp output files are making the trip to your server, particularly all those quirky little things in the whdata, whgdata, and whxdata folders?
Good luck,
Leon
See Snippet 57 on my site.
Images are best included in a post by using the camera icon above. Attached images get queued so there is a delay, PDFs seem to want to be saved on viewer's PCs. Images inserted with the camera can be seen straight away. Thanks.
Follow me @petergrainge
Good luck,
Leon
MergeThis was right - for some reason, there were numerous missing files in the "whdata," "whgdata," and "whxdata" folders in our configuration management tool. After uploading the missing files and deploying a new build, that appears to have resolved the issue.
Matt
