The following grid provides the correct drop down list but
when displaying the value of the column it show the actual value
and not the display value that I want. It should be showing
initials and not the ID for those initials stored in the database.
You can go to tax.avericom.com/control and log in as
temp/AdobeLabs. On the drop down menu select client services then
client searches. Type 2478 as the search number in the top box then
select it from the list. When the next page loads, click on the
candidates tab. The recruiter_referral column should show the drop
down. If the entry is blank the drop down works properly. If it is
not blank, only the selected item show. The value in that column
shows the stored value from the database and not the corresponding
value from the list.
