Help needed with forms
Avatar
Level 1
Hi I have created a form for a client in LiveCycle ES and they want the form to have the following actions:
1. Client A will fill the form in and send to the Client B.
2. The form needs to have a password on so Client B can not be alter it.
3. Client B then needs to be able to send the form back to two email address with the submit button to Client A and to a central PC when the database will be stored.
Avatar
Level 10
"2. The form needs to have a password on so Client B can not be alter it."
  This means the client B can read the PDF but cannot alter it. Am I correct?
  If so you can either:
           1. Make all fields read-only using scripting
           2. Flatten the PDF so that it cannot be altered anymore
           3. Apply Usage Rights and set password so that the client B can read the PDF only supplying the correct password.
"3. Client B then needs to be able to send the form back to two email address"
     It is as simple as you route the task back to client A and the central PC.
Hope this will help you.
Nith
Avatar
Level 1
Hi $Nith$
thanks for your reply,
I have managed to get hold of a script and alter it so it sends to two email address when you hit the email button.
When I set a password in the form properties it will not let me distribute the form.
What I need the form to do is client A fills in the form, then sends it to client B, client B looks at the data on the form (but is unable to change the data) then sends the form back to the two different email address (which will be client A's & the central PC with the database on). Then the database PC will open the form and be able to create a database of the forms.
Avatar
Level 10
So you can flatten your pdf using transformPDF activity.
Nith
