1. Re: Can you change the format of text in Track Text Edits?
Arnis Gubins Oct 8, 2009 3:04 PM (in response to farrelldoc)Karen,
The track edit changes are just special formats of Condition Catalog items that are unfortunately hardwired. You can save them as MIF, edit the color, e.g.
<Condition
<CTag `FM8_TRACK_CHANGES_ADDED'>
<CState CShown>
<CStyle CUnderline>
<CSeparation 10>
<CColor `Forest Green'> <-- change to Blue ro whatever is defined in the Color catalog.
<CAndCondition >
> # end of Condition
<Condition
<CTag `FM8_TRACK_CHANGES_DELETED'>
<CState CShown>
<CStyle CStrike>
<CSeparation 2>
<CColor `Red'>
<CAndCondition >
> # end of ConditionHOWEVER, FM dutifully changes these back when you re-open the MIF fle. No can do manually.
IIRC, I believe that Rick Quatro has written a Framescript that does some magic here. You might want to contact him - see:
2. Re: Can you change the format of text in Track Text Edits?
farrelldoc Oct 8, 2009 4:35 PM (in response to farrelldoc)Thank you so much! I have contacted him.
Karen
3. Re: Can you change the format of text in Track Text Edits?
farrelldoc Nov 19, 2009 7:46 AM (in response to farrelldoc)Going back to this topic--does Adobe have plans to make the Track Text Edits formatting editable in future releases? I was unable to purchase a solution, so I have been using conditional text to indicate the changes and deletions, which, of course, will have to be manually removed when they are approved. It would be so much easier if I could use Track Text Edits!
Thanks so much for your help,
Karen
4. Re: Can you change the format of text in Track Text Edits?
Jeff_Coatsworth Nov 19, 2009 8:27 AM (in response to farrelldoc)You should post this over on the FM Feature Requests thread & use the "official" path there to submit it to Adobe
5. Re: Can you change the format of text in Track Text Edits?
farrelldoc Nov 19, 2009 8:59 AM (in response to Jeff_Coatsworth)Good idea. Thanks!
