i am trying to create a senario in my xml doc where there can be many <forpage> entries for each message. the following loop creates incomplete entries
in <forpage> see below.
//convert list of <forpage> to an array for looping below
<cfset myArrayList = ListToArray(opt)>
<cfset arrayInsertAt(xApps.messageList.xmlChildren,1,xmlElemNew(xApps,'message'))>
<cfset xApps.messageList.message[1].sender = xmlElemNew(xApps,'sender')>
<cfset xApps.messageList.message[1].sender.xmlText = "#send#">
<cfset xApps.messageList.message[1].creator = xmlElemNew(xApps,'creator')>
<cfset xApps.messageList.message[1].creator.xmlText = "#creat#">
//the loop attempts to enter multipe entries for <forpage>. <forpage> is converted from a list to an array
<cfloop from="1" to="#arraylen(myArrayList)#" index="j">
<cfset arrayInsertAt(xApps.messageList.message.xmlChildren, j,xmlElemNew(xApps,'forPage'))>
<cfset xApps.messageList.message[1].forPage = xmlElemNew(xApps,'forPage')>
<cfset xApps.messageList.message[1].forPage.xmlText= "#myArrayList
</cfloop>
this code produces the following entry in my xml doc
<messageList>
<message>
<sender>jljkjlkjlkj</sender>
<forPage/><forPage/>
<creator>lkjlkjljlkjklj</creator>
<forPage>three</forPage>
</message>
</messagelist>
any thoughts would be appreciated. thank you for your time
I am not sure what results you are trying to receive.
But I'm gussing that somehow or the other you want different values so the only guess I can make is to add an array index to the forPage elements.
<!--- <cfset xApps.messageList.message[1].forPage= xmlElemNew(xApps,'forPage')> I beleive this line is redundant --->
<cfset xApps.messageList.message[1].forPage.xmlText= "#myArrayList #">
</cfloop>
yes that worked. i should of saved
my old code because i tried something similiar to that. below is what i was shooting for. thanks for your time
<messageList>
<message>
<forPage> abc application </forPage>
<forPage> intranet </forPage>
<forPage> home </forPage>
<sender>john</sender>
<creator>bob</creator>
</message>
</messagelist>
