Using Flex Code in Flash
Avatar
Level 1
Hi everyone,
I really hope you can help me with this. Here's my
situation...
I've developed a flex application that connects to another
java application using "BlazeDS". It works great!! The reason why I
did this is because I'm developing (along with a Flash designer) a
website of a music band, and I use java to connect to a database
that has all the "gigs", news and subscribers to the website.
Everything works great in Flex, my problem is I'm not a
designer, I'm a developer. So I wanted to know if there's a way I
can just give my designer friend a code so he can use it in Flash
CS3?? (Like to send him objects containing the info. For example,
give him a concerts object that contains the date and the location
so he can build the datagrids for the concerts page in Flash)
I think there must be a way to use Flex libraries in CS3, or
maybe create some kind of Flex class that will work as a
"communication interface" between the database and the flash code,
I'm really not sure...
In other words, I need to know how can my designer friend use
(in Flash) what I've developed in Flex.
Please let me know if there's a way...
Just in case you need to know, I use Flex's Eclipse plug in
(it's easier for me this way cause I have java and flex in the same
place!)
Thanks!!!!!!
