We have built several webservices accessing our test database.
Installed SoapUI, added WSDL files to SoapUI, entered data into XML requests, - tested against our webservices - all worked as a charm!
Then tried them with Flex 3.
Created a project, imported WSDL, downloaded Adobes's US weather example from http://www.adobe.com/devnet/flex/articles/flex_ws.html
and, by example, wrote a similar code to work with our webservices. Tested - received the following error:
<errorMessage>Error in SOAP body: Unable to resolve namespace URI for ''''''''''''''''''''''''''''''''. (10915)</errorMessage>
Then we compared Requests sent by SoapUI that worked, and by Flex that did not.
Here are both requests.
SoapUI:
<soapenv:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:PoirotWebServices-org:poirot_web_services" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/">
<soapenv:Header/>
<soapenv:Body>
<urn:appsvc_AvailRQ soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<ipt_BookingOffice xsi:type="xsd:string">LON</ipt_BookingOffice>
<ipt_BookingCurrency xsi:type="xsd:string">GBP</ipt_BookingCurrency>
<ipt_TourCode xsi:type="xsd:string">NALNWICK</ipt_TourCode>
<ipt_TourDate xsi:type="xsd:date">2008-04-19</ipt_TourDate>
<ipt_NumberOfPax xsi:type="xsd:int">2</ipt_NumberOfPax>
<ipt_MarketingCode xsi:type="xsd:string"></ipt_MarketingCode>
<ipt_RailResourceCode xsi:type="xsd:string">NBL,SHE,ALN,,,SHE,</ipt_RailResourceCode>
<ipt_InsuranceCode xsi:type="xsd:string"></ipt_InsuranceCode>
<tSSR>
<!--Zero or more repetitions:-->
<tSSRRow>
<bkifrloc></bkifrloc>
<printResKey></printResKey>
<ssrCode>PBK</ssrCode>
<ssrPrice>12</ssrPrice>
<ssrPaxNumber>1</ssrPaxNumber>
<ssrQuantity>2</ssrQuantity>
<ssrRemark>test remark</ssrRemark>
</tSSRRow>
</tSSR>
</urn:appsvc_AvailRQ>
</soapenv:Body>
</soapenv:Envelope>
Flex:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<SOAP-ENV:Body SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<S2:appsvc_AvailRQ xmlns:S2="urn:PoirotWebServices-org:poirot_web_services">
<ipt_BookingOffice xsi:type=":string">LON</ipt_BookingOffice>
<ipt_BookingCurrency xsi:type=":string">GBP</ipt_BookingCurrency>
<ipt_TourCode xsi:type=":string">NALNWICK</ipt_TourCode>
<ipt_TourDate xsi:type=":date">2008-04-19</ipt_TourDate>
<ipt_NumberOfPax xsi:type=":int">2</ipt_NumberOfPax>
<ipt_MarketingCode xsi:type=":string">PTB4</ipt_MarketingCode>
<ipt_RailResourceCode xsi:type=":string">NBL,SHE,ALN,,,SHE,</ipt_RailResourceCode>
<ipt_InsuranceCode xsi:type=":string"></ipt_InsuranceCode>
<tSSR SOAP-ENC:arrayType="S2:appsvc_AvailRQ_tSSRRow[]" xsi:type="SOAP-ENC:Array" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/">
<item xsi:type="S2:appsvc_AvailRQ_tSSRRow">
<bkifrloc xsi:type=":string"></bkifrloc>
<printResKey xsi:type=":string"></printResKey>
<ssrCode xsi:type=":string">PBK</ssrCode>
<ssrPrice xsi:type=":decimal">12</ssrPrice>
<ssrPaxNumber xsi:type=":int">1</ssrPaxNumber>
<ssrQuantity xsi:type=":int">2</ssrQuantity>
<ssrRemark xsi:type=":string">test remark ssr</ssrRemark>
</item>
</tSSR>
</S2:appsvc_AvailRQ>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Then we compared these two XMLs.
Found that 1) if we add "xds" into all data definitions like xsi:type=":decimal" to make it look like xsi:type="xds:decimal"
and 2) if we replace the envelope definition
with a version from SoapUI
then the modified "Flex request" will work too.
My question is - what can we do to make Flex gererate same Request formats as SoapUI does ??
Thank you
