When I use following coding in my project, I got javascript error. This error shows as follow :
error: http: Error retrieving markup for element editWindow_body : Not Found......
<cfajaximport tags="cfwindow">
<script>
function makeWin(x,y) {
ColdFusion.Window.create('mywin','Windows Rules','win.cfm',{x:x+25,y:y+25});
</script>
<h2>Test</h2>
<p>
This is the test <a href="" onclick="makeWin(event.pageX,event.pageY);return false;">link</a>.
</p>
All responses will be appreciated.
Make sure the page win.cfm exists within the current directory.
Nope. This file exists in current directory.Here is error message :
I recently came across this blog, where I found something like, If we have any variables (or) form controls named as "action", then this error is bound to occur...
Here is the link,
http://blog.garthe.com/index.cfm/2008/1/2/CFWINDOW-and-CFFORM-doesnt-like-action-hidden-form-variable
HTH
It's kinda useful link. But, it can't erase javascript error from my page. For this error, do I need to do any configuration in CFADMINISTRATOR?
That means you tried changing those occurences of "action" into some other name, and still you face the same issue?.
Can you please post your complete code here if possible?.
<script>
function makeWindow(ID) {
var d = new Date();
var curr_hour = d.getHours();
var curr_min = d.getMinutes();
var curr_sec = d.getSeconds();
ColdFusion.Window.create(curr_hour + curr_min + curr_sec,"The Title","windowSource.cfm?ID=" + ID,
{center:true,modal:true,width:800,height:600,resizable:false});
</script>
<a href="##" onClick="makeWindow('MyWin')">Open Window</a>
So what's in the windowSource.cfm file? The error is complaining about that file, not the mainline code.
Adam
Yeah.. Adam is 100% correct..
When I created one test template with "windowSource.cfm" it worked perfectly.
Here is coding in windowSource.cfm. But, whenever I click on the link of main file, error come out just like before.
<html>
<head>
<title>Test</title>
</head>
<body>
<cfoutput>#ID#</cfoutput>
</body>
</html>
Your windowSource.cfm code works well for me.. Not sure what goes wrong there?. Have you checked your logs?.
It works for me too.
What happens if you browse directly to windowSource.cfm, providing it with the correct URL param?
The windowSource.cfm call is a separate request... could an Application.cfm or onRequestStart() call be contributing to this?
Adam
Oh gosh..!! Thanks all. It's because of my application.cfm file. When I create new website and make like before, it's fine.
Thanks for your time all.
