decode UTF-8 to ISO-8859-1
Contributor ,
Nov 23, 2009 Nov 23, 2009
I am using the Google Maps API, it return in utf-8,
so for some countries, caracters are wrong,
My server is ISO-8859-1
So, how to convert the result from utf-8 to iso-8859-1 ?
I tried :
<cfprocessingdirective pageEncoding="UTF-8">
<cfcontent type="text/html; charset=UTF-8">
<cfset setEncoding("URL", "UTF-8")>
<cfset setEncoding("FORM", "UTF-8")>
and
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
No change. always the wrong caracters,
Thanks for any help with this mess.
Pierre.
Advanced techniques
3.3K
Advocate ,
But your ColdFusion is not necessarily using the same charset as your server.
Which version of CF are you using? If you are using CF 5 or older, forget it. If later, it should work out of the box if you use the appropriate charset attributes everywhere. Can you explain a bit more about the processing code?
Hi!
Try this trick:
<cfsript>
s="your_text";
chr_current="your_current_charset";
chr_new="your_new_charset";
c=createobject("java", "java.lang.String").init(s);
convstring=createobject("java", "java.lang.String").init(c.getbytes(chr_current),chr_new).tostring();
</cfscript>
Contributor ,
Nov 24, 2009 Nov 24, 2009
I am using CF v7.
My server and CF are ISO-8859-1.
But I am using Google Maps API , which returns country names in UTF-8.
I tried the Google Maps directives, with adding parameter eo=ISO-8859-1 in the Google Key <script>,
same result.
Then  I have to convert to ISO-8859-1 , at least in that page for country names.
(I have a specific problem with Thailande, Google Maps returns :  Tha๏lande
and in the data base it writes : tha&#3663 ;lande   (an Access database)
I answer to injun [576871]  ,
Diificult to insert that code, because I am in a JavaScript code already.
So it will not accept <cfscript> again inside ? I will try.
Thanks for any help.
Pierre.
Contributor ,
Thanks, I will try at end of day,
I have a meeting right now.
Regard, Pierre.
Pl-Art - Pierre LARDE
http://www.pl-arts.com
Email : pierre@pl-arts.com
Tel : 04 93 60 48 91
Auberge de la Clue, 06850, St Auban
Contributor ,
I tried it before the insert Query,
But I get the same value :
Before : Tha๏lande
After : Tha๏lande
here is the code :
What do you think of ?
Thanks for all.
Pierre.
Contributor ,
I answered by mail, and the code has not appeared
here is the code used :
<cfoutput>
before : #form.pays#<br>
<cfscript>
s="#form.pays#";
chr_current="utf-8";
chr_new="ISO-8859-1";
c=createobject("java", "java.lang.String").init(s); convstring=createobject("java", "java.lang.String").init(c.getbytes(chr_current),chr_new).tostring();
</cfscript>
after : #convstring#<br>
</cfoutput>
Pierre.
Documentation
