I am working in Office 2007, in parallels on my Mac.
Hello,
Had the same issue when installing the Presenter patch. Could you go to the Powerpoint Options (under the Office button upper left), to Plug-ins and then look if the Presenter plugin has been deactivated (not sure of the right terminology, because I'm using a Dutch version of PPT)? If yes, you should be able to reactivate it from this menu. I will try to find the thread in this forum with a more detailed explanation if you do not succeed.
Lilybiri
PS: here is the thread: http://forums.adobe.com/thread/506350?tstart=30
Sounds like the Presenter addin has been disabled by Office.
http://msdn.microsoft.com/en-us/library/ms268871(VS.80).aspx:
In the application, click the Microsoft Office Button.
Click the <ApplicationName> Options button.
In the categories pane, click Add-ins.
In the details pane, locate the add-in in the Disabled Application Add-ins list.
The Name column specifies the name of the assembly, and the Location column specifies the full path of the application manifest.
In the Manage box, click Disabled Add-ins, and then click Go.
Select the add-in and click Enable.
Click Close.
