I made the same mistake of downloading to a computer that wasn't signed in. There was no warning though, I thought it was authorized.
I purchased an eBook from Cokesbury.com and downloaded it to my desktop (which wasn't authorized to my email). It will not work on my laptop which is authorized. Emailed Cokesbury and they told me to just go ahead and authorize the desktop - I didn't do it because there were warnings that I might loose access to the licenses.
So now, it doesn't work on the desktop either... it now tells me:
Document is licensed for a different user account
And the laptop continues saying:
Error getting license
License server communication problem:
E_LIC_ALREADY_FULFILLED_BY_ANOTHER_USER
Cokesbury sent me to Adobe support. I didn't even read the book and I bought it for class. Can someone please help?
try this link
/10/133/en/Help-Tech-Format410.htm#questionhttp://www.harpercollinsebooks.com/E7D36F92-6CF5-49E3-BF08-D272C757716F-606
quoting:
Hi
I just got this problem and I am using a mac and a PC basically I registered with my email address on one and made a typo on the other however simply reactivating was not working for me so I could not read my new book. Trawling through the net I feel sorry for everyone who has this issue with no fix.
I managed to fix the problem buy going to regedit
Hkey_current_user\software\adobe\adept etc you will see the registration details under there. I in fact exported the whole adobe key ands save dit just in case I needed to restore it but I dont have another other adobe apps installed. Once I deleted the key and reinstalled ADE I got prompted to re-activate it again properly and entering the correct email address it helped.
I would say just be careful for those of you may have other adobe products, if you cannot find the right key to delet reply to me and I will try and help idf we think its the same issue
I have the same problem and I cannot resolve the issue. I renamed the file in the register and it allowed me to
authorise again - and that says all ok, but I still get the error and cannot copy purchased downloads.
thanks
I've sorted it
I trawled through the Registry 'regedit' and looked at all the DigitalEdition entries until I found which seemed incorrect
- yours may be different, but this had entries which did not correspond with my set up -
HK_USERS/(key_name)/SoftwareMicrosoft/Windows/CurrentVersion/Explorer/ComDIg32/PDF/MURList
After this I then got another error which would not allow me to copy over the purchase book, and I proceeded as follows
* Exit Digital Editions, but ensure your reader is plugged in
* Make up a backup copy of manifest.xml - stored in
e.g. c:\Documents & Settings\Your_User_Name\My Documents\My Digital Editions
* Seach for deviceID and remove all the entries between <de:deviceID> to </de:deviceID> leaving in these tags
* Save the file
* Open Digital Editionals and it should come up and ask you to Authorise
- do so
When attempting to download an Adobe eBook a second time, I received the error 'Error getting license/License server communication problem: E_LIC_ALREADY_FULFILLED_BY_ANOTHER_USER'. What should I do?
In order to download a single Adobe eBook on multiple computers, Adobe Digital Editions must be activated using the same Adobe ID on each computer.
To activate Adobe Digital Editions using an Adobe ID…
Contacted Adobe support who gave me a list of instructions which included uninstalling Digital Editions, deleting registry files, deleting ebook files (after saving them elsewhere), emptying trash folder and rebooting (unfortunately this didn't work).
However when I carried out a simple system restore (start > all programs > accessories > system tools > system restore) and went back to a restore point before I had authorised Digital Editions this worked and I was able to access all my ebooks again.
Thank you for the tip. But the thing is that I changed computers and just have the copies of my e-books. That is why each time I try to open ADE, it tells me that it is registered to another account .
Ney
--- En date de : Jeu 11.3.10, elainewild <forums@adobe.com> a écrit :
De: elainewild <forums@adobe.com>
À: "Ney LODY" <neylody@yahoo.fr>
Date: Jeudi 11 mars 2010, 12h08
Adobe needs to come clean with this rotten product. Angus robertson has reset my licenses several times, and still i have this problem.
I am starting to feel guilty in getting on them, must be Adobe's problem
Don't know where to turn. Anyone starting an official legal complaint we can all join in on?
Hi Everyone,
I have found the message comes from using two different accounts. For example, if you downloaded the book on someone else's computer into ADE, then it is their email address and password you need to use to open the book in.
I had changed my email address, there for my adobe digital editions ID. I now have to switch back and forth in order to read the books. You can also check with the website you bought the books from, tell them your issue about Digital Editions and some people have had success in the website resending the book so you can authorize the new version under your own ID.
Hope this helps. I will try KOBO and see if they can resend the book.
Oh, I also went through the phone calls with adobe and the web as well. No help what so ever and they wanted 39.00 to help me with a free product. Didn't do it. I'll just either switch back and forth with my ID's or ask Kobo to resend the books.
Here's what FINALLY worked for me. I have NOOK, but it is possibly the same problem and procedure. I was able to read on my ADE on my computer, but not on my Nook (files I had bought from KOBO). I was getting USER NOT ACTIVATED error or ERROR GETTING LICENSE message.
On my NOOK, (Plug into your computer and find it as a drive. You can see the folders on it) I deleted the ADOBE DIGITAL EDITIONS folder that I could see. On my MAC, there is also another INVISIBLE FOLDER called .adobe-digital-editions. I think (but I'm not sure) that this file is visible on windows and you can just delete it. For MAC, OSX.4 or higher use this:
I found a dashboard widget called hiddenfiles, at this link:
http://www.apple.com/downloads/dashboard/developer/hiddenfiles.html
Download this and install. It will seem like nothing happens, but then when you open your nook drive (the nook drive that shows up on your desktop when you connect by usb cable) you can see that folder called .adobe-digital-editions
I deleted the whole folder. It has information about the rights of the books, etc., and if there are old files in there or some that conflict (maybe you had the ADE before you registered your nook, bought with a different account somewhere, who knows what!!)
This causes your Nook to be deactiviated, so the next time you connect and open ADE it will ask you to re-authorize your nook. Do so. Then drag your books from ADE. They should (worked for me - YAYYYY I am so happy!!) now show up in your documents on your nook and most importantly of all - OPENNNN!!!!!
Finally!!!!!!!!!!!
Thank you, I don't have a mac, but i followed the instructions to delete all adobe digital editions on my nook folder when connected with usb. reopened app and was finally prompted to activate my device and was able to open my books!! Thanks user to user forums. As useful as Adobe products and downloads are, their customer service is just horrible. No offense to "oversea" customer service, but shame on Adobe for lack of training. Anyways, I am happy now.
In case I wasn't clear, I have to deauthorize my ade by pushing ctl+
shift+D, then re-start ADE, then log in the email address and password. This is what I meant by logging in under another person's email address and password in ADE.
Thank you so much! Your solution is the life-saver.
I am also having the same problem. I do not want to mess with my registry, I cannot restore my system to a earlier time, and while I do appreciate these suggestions from the fellow members, ADOBE has yet to offer any (real) solutions. A link to the "Help" section and copy/pastes of the FAQs do not provide much value beyond stating the obvious.
Adobe, you have left me frustrated and dissatisifed with your brand due to inferior support and troubleshooting infromation.
Adobe online support directed me to this link http://forums.adobe.com/thread/314992 LOOK familiar ?????
Then they said open a support ticket
Karal : 1. Sign into the Customer Support Portal at www.adobe.com/go/supportportal
Karal : 2. Type in your Adobe ID and Password and then click Sign in
Karal : 3. Under Get Support, click Technical Support tab and choose the product.
Karal : 4. Click "Continue" button and proceed to online form.
Karal : 5. Fill in the required fields (asterisk), and click Review Case and Submit.
Karal : Our tech support specialist will follow up with you through the same case. Please make a note of the Web Case number.
Come ON... for a company that has $1.32 BILLION in operating cash flow.. you would think they can create a product that actually works.. or hire people who can actually support ?
BTW.. see this article... looks like those books that were in my list to download did not work anymore. I was able to add a new book to my list and download it.
I cannot believe how frusterating this is. All I want to do unauthorize the ADE on my computer. I tried uninstalling and deleting the hidden files, however, it still shows my old email as the authorized computer. Can someone help with this?
It is so frusterating to not be able to read the books I purchased.
You may be running into a digital rights issue. There's a technical article
that may help HERE
<http://technology.myblogzone.info/2011/01/how-to-solve-the-error-getting-license-message-in-adobe-digital-editions/>.
I hope it helps you.
