1 2 Previous Next 58 Replies Latest reply on May 27, 2013 3:10 AM by Akiratorishi
    AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
      How do I work around the following fatal error:  AccessViolationException
      Steps to reproduce the error:
      1.  In MS VisualStudio 2008, Create a Windows Form Application, add a Panel and a Button components to the form.
      2.  Add a Reference to the Acrobat COM component for AxAcroPDFLib
      3.  Add the following code to the main form:
          private AxAcroPDFLib.AxAcroPDF ax = new AxAcroPDFLib.AxAcroPDF();
          private void button1_Click(object sender, EventArgs e)
            panel1.Controls.Add(ax);
            ax.LoadFile(@"c:\temp\myfile.pdf");
            ax.setView("Fit");
      4.  Run the application
      5.  Click the Button
      6.  Press the TAB key on the keyboard.
      Result:  The application crashes with an AccessViolationException:  Memory Corrupted error.
      Note:  I had been working on an application for about a month now, but had Never pressed the Tab key while the application was running until today!!
      Although I did not yet test EVERY key, all other keys and activities inside and outside of the Acrobat component, application, and OS seem to work ok.  I can't deploy an application to production if it will crash on Tab keypress.
      Platform:
      Windows 7, 32bit, all current updates
      Acrobat 9 Standard, all current updates
      Microsoft Visual Studio 2008 Professional, all current updates
      I'm not an Acrobat SDK developer expert, so this may be some simple configuration setting.
      Any assistance is greatly appreciated.
      Arnold
        • 1. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
          lrosenth Adobe Employee
          We are aware of the tab issue but I am pretty sure that it was fixed in 9.2 (the current update).  Can you verify that you are on 9.2?  Also, are you in Acrobat or Reader?
          • 2. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
            AccessViolationException Level 1
            I verified Acrobat's Help/About:  Version 9.2.0 Standard
            Windows 7 Enterprise (32 bit).
            I tried .NET Frameworks 2.0 and 3.5.
            I didn't try Acrobat Reader.  Will the Reader behave differently?  The final application is for Viewing/Read Only, so I won't need the features of the Standard edition beyond what the Reader comes with.  My impression was that I needed the Standard or Pro version license to embed the viewer into a workstation application.
            Arnold
            • 3. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
              You don't need Standard or Pro - whatever the user has on their computer is what will be used.  No "licensing" involved since you aren't distributing any Adobe parts.
              • 4. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                Acrobat 9.2 Standard definitely does not work with Microsoft Visual Studio 2008 interop.  The Tab key is the killer.  I'll try the Reader now and post the results.  I need to resolve this or else I will be forced to use a more stable PDF viewer component.
                • 5. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                  Acrobat Reader 9.2.0 crashes with the same AccessViolationException fatal error using Visual Studio 2008, Windows 7, and .NET framework.
                  This is not good.
                  Please let me know ASAP when this problem is fixed.  I would really like to use Adobe Acrobat and the Acrobat SDK instead of a third party viewer.
                  Arnold
                  • 6. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                    Looks like Acrobat will be dead for us in Windows 7 until this problem is fixed.  I cannot get Acrobat 8 Reader to install in Windows 7, so until Acrobat 9.2.0 is fixed in Windows 7, we have to use a third party PDF viewer.
                    This was really unexpected!
                    Attention ADOBE:  Please fix the <TAB> key problem in Acrobat 9.2.0 in Windows 7 and notify me ASAP as soon as the fix is ready.
                    • 7. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                      As I already said, we are aware of the problem and will release a fix as soon as possible in our current update schedule.
                      • 8. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                        Tournieux
                        I am running Reader 9.2.0, using XP, VS 2008 and the issue is still here.
                        it has not been fixed in the Reader 9.2.
                        Have you any information about next version which will fixe the issue ?
                        Is there any workaround meanwhile ?
                        Thank's.
                        • 9. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                          Matthew Snapp
                          I just tested this with Acrobat 9.3.1 on Windows XP and Windows Vista.  This issue still exists, and has existed since Acrobat 9.0.  There is an untrappable exception thrown when the user attempts to tab out of the AcroPDF control.  Additionally, once a document is opened in the AcroPDF control, all keyboard keystrokes apply to the AcroPDF control, not the main application form.  As a result, users with accessibility requirements cannot tab back to the application main menu or toolbar to continue operating the application once a document is opened.
                          I am using the AcroPDF control in a Windows executable application written in Visual Basic .NET 2008.  Purchase of Acrobat Standard or better by the client for each PC that will have my application installed is a prerequisite for purchase.
                          My product cannot pass US Federal Government Rehabilitation Act Section 508 Requirements until this issue is resolved- effectively locking me out of the Federal Government market.
                          Does Adobe recommend another PDF viewer that developers should use that will allow Accessibility in their applications?
                          • 10. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                            I believe this was bug #2393752 which is fixed in 9.3.2.
                            • 11. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                              Calloway333
                              It is definitely NOT fixed in 9.3.2.  At least with VB.Net 2005 on WinXP
                              • 12. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                Calloway333 Level 1
                                Here is a workaround I've found.  I haven't had any problems with it (yet), but you'll want to test it out in your application.
                                I was able to trap the error and prevent it from display by adding an error handler in the load event of my form and the handler subroutines.
                                This catches the error and prevents the user from seeing it.
                                I added this code to my form's load event:
                                Dim currentDomain As AppDomain = AppDomain.CurrentDomain
                                'for threads behind forms
                                AddHandler Application.ThreadException, AddressOf MYThreadHandler
                                and I declared the sub below.  I just want to catch and suppress this error, so I have everything in the subroutine commented out.
                                Sub MYThreadHandler()
                                ' Handle the event.
                                'MsgBox.Show("MYExceptionHandler caught event.")
                                End Sub
                                Hope this helps.
                                1 person found this helpful
                                • 13. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                  Calloway333 Level 1
                                  Forgot to say that I'm using my workaround above is used with Adobe Reader.  Seems to work with 9.3.1 and 9.3.2.  I haven't tested it with anything else.
                                  • 14. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                    Just a follow up.  my project was deployed in January and its Acrobat is updated to the current version of Acrobat at this time.  However, the application is a Touch Screen application, so I can't tell if the problem is resolved - since there is no keyboard attached.  It is my hope that the problem is fixed so my next project development will not have the same issue.
                                    Arnold
                                    • 15. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                      aucha
                                      Ok, guys,they do not seem to fix the problem after about a year of first finding it. I am using Adove Reader 9.3.2 and the bug is still there.
                                      I found the workaround which works perfectly.
                                      In the window where you've created the Adobe PDF Reader Active X control override the OnPretranslateMessage() method.
                                      Paste the following chunk of code to block the internal Adobe's Application message 0x1450 (5200L). If you do not use MFC or C++, then find a place to override message processing.
                                      BOOL CMyDialog::PreTranslateMessage(MSG* pMsg)
                                        // insert this chunk of code.
                                        // Replace m_pdfCtrl with the name of your Adobe control.
                                        if(pMsg->hwnd == m_pdfCtrl.GetSafeHwnd())
                                          if(pMsg->message == 0x1450)
                                            return TRUE;
                                        return CDialog::PreTranslateMessage(pMsg);
                                      BTW, I've send the detailed report to Adobe with the steps to replicate, and as expected no reply from them. Good for you, Adobe.
                                      • 16. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                        Akiratorishi Level 1
                                        Hello to everyone.
                                        The TAB  exception STILL EXISTS in the X (10) version.
                                        The activex generates the same problem both on .net projects and on borland c++ builder projects(no .net but classis COM).
                                        The last answer workS(Pretranslatemessage)!
                                        What you have to do is contained in this link http://geekswithblogs.net/Jaggi/archive/2006/02/02/67999.aspx.
                                        Obviously you have to process the write key message "0x1450" and not WM_KEYUP.
                                        • 17. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                          Maretine
                                          Working in Access, I'm getting the same fault as everyone else in this thread.
                                          • Have disabled tab stops for all controls (including the Reader control) - still occurs.
                                          • Have the Form_KeyDown event capturing vbKeyTab and setting it to 0 - still occurs.
                                          • Have used Private Declare Function GetAsyncKeyState Lib "User32" (ByVal vKey As Integer) As Long to intercept the Tab's
                                            (but can't find a way to consume the Tab out of the keyboard buffer and am assuming that is why the Reader control still reacts to the Tab)
                                          If anyone knows of a way to implement the PreTranslateMessage workaround posted by aucha in VBA, it'd be greatly appreciated.
                                          • 18. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                            aucha Level 1
                                            Hi guys,
                                            I'd like to provide you with an update. Back in June 2010 I have lodged an Adobe product Security vulnerability incident report via the Adobe website. It took them 8 months to come up with a solution. The solution is however is not perfect. You need to copy a Microsoft legacy MFC dll MFC71.dll. There is no way you can download this dll officially from the Microsoft website, as they are apparently dropped support for this version of MFC.
                                            Below is the copy of my conversation with Adobe
                                            Sent: Thursday, February 03, 2011 2:04 PM
                                            To: aucha
                                            Subject: RE: Adobe product security vulnerability feedback form (586)
                                            Hello aucha,
                                            Thank you again for your report of Adobe ID 586.  Our investigation of this issue found the problem to be related to MFC71.dll , which was not installed in the case of AcroView.exe. After manually copying the MFC71.dll to the same folder as Acroview.exe (alternatively, MFC can be statically linked with the program), no crash was observed.  If your investigation proves otherwise, please let us know.
                                            Again, thank you for your continued help and discretion.  Please let us know if you have any questions.
                                            Thank you,
                                            Wendy
                                            Adobe Product Security Incident Response Team
                                            -----Original Message-----
                                            Sent: Wednesday, June 16, 2010 12:03 PM
                                            To: aucha
                                            Cc: Adobe PSIRT
                                            Hello aucha,
                                            Thank you for your report.  We have been able to reproduce the issue and are currently working on a fix.  We will be in touch with additional information as available regarding an eventual release schedule.  In the meantime, we appreciate your help in not publicly disclosing this potential issue in order to protect Adobe's customers.  This has been assigned the Adobe tracking number 586.
                                            Thank you again for your help and discretion!  Please let us know if you have any questions.
                                            Thank you,
                                            Wendy
                                            Sent: Thursday, June 10, 2010 12:49 AM
                                            To: Adobe PSIRT
                                            Subject: Adobe product security vulnerability feedback form (586)
                                            Email: aucha
                                            Phone:
                                            CanAdobeContactUser: Yes
                                            Product: Adobe Reader
                                            ProductOther:
                                            ProductVersion: 9.3.2
                                            VulnerabilityDetail: I am a Senior Software Developer responsible for application design and development at our company. Our team has identified a vulnerability in 'Adobe PDF Reader <1.0>' Active X (IAcroAXDocShim) control residing in AcroPDF.dll. When the control is placed on a dialog form and a pdf file is loaded, then hitting <Tab> key causes the application to crash.
                                            I have researched the Internet and found that this issue has been observed by someone at lease a year ago in version 8, and apparently has not been fixed since.
                                            As far as I know MS Internet Explorer has a workaround for this issue.
                                            Please advise if this will be fixed, or if there is a know workaround for this.
                                            aucha
                                            DefaultConfigVulnerable: Yes
                                            ConfigChangesRequired:
                                            VulerabilityResult: DataLossCorruption, DenialServiceApplication
                                            PartiesAffected: ProductOwner, ThirdParty
                                            HowToDuplicate: Create a simple MFC Dialog based application in Visual Studio.
                                            Add new MFC class using VS wizard 'MFC Class from Active X Control'.
                                            Locate 'Adobe PDF Reader <1>' in the list of installed Active X Controls in the system.
                                            Generate a class for the IAcroAXDocShim interface.
                                            Create a pdf control on the default MFC dialog in OnInitDialog() method.
                                            Load a document using LoadFile() method.
                                            Run the program.
                                            Set Focus to the Adobe reader control using mouse click. Tab out of the control by pressing <Tab> key.
                                            The program crashes.
                                            If having troubles creating an MFC project, please load one from codeproject: http://www.codeproject.com/KB/miscctrl/acroview.aspx
                                            ExampleProgram: Yes
                                            WorkaroundsFixes: Yes
                                            WorkaroundsFixesDetail: There is no any crashes in Internet Explorer. Microsoft must have done something. Please check with them please.
                                            At the same time they implemented additional interfaces (such as IAcroIEHelperShimObj, DWebBrowserEvents2, etc). There is no information about these interfaces in the SDK documentation, so I guess they are designed specifically for MS
                                            VulnerabilityBeingExploited: Yes
                                            • 19. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                              aucha Level 1
                                              As Akiratorishi said, you need to intercept 0x1450 message, not KeyDown message. You need to find our how to use the analog of PreTranslateMessage in MS Access
                                              • 20. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                Maretine Level 1
                                                That's my difficulty.
                                                I've been able to find examples of how to do that in C#, nothing for how to do it in Visual Basic for Applications - and VBA is sufficiently different from VB.Net that a straight transation from C# -> VB.Net doesn't work.
                                                • 21. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                  aucha Level 1
                                                  In this case you can try the MFC71.dll approach (see my previous post). You can then tell us all, if it worked (I myself personally did not test it, as I do not have time at the moment)
                                                  • 22. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                    I don't understand this, since Acrobat doesn't use MFC....
                                                    • 23. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                      Maretine Level 1
                                                      The version of MFC71.DLL on my machines is 7.10.3077.0 - from 2003 which as far as I can find is the most recent one, and I can't find any legacy versions.
                                                      Even the oldest box left in the office which is running XP has ver7.10.3077.0
                                                      -- Edited to remove my email sig that was included inadvertently.
                                                      • 24. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                        DBuschow
                                                        Hello Irosenth,
                                                        I've updated to Adobe Reader X and my customers and I still have this issue.  Loading the pdf document and hitting the "TAB" key crashes the ActiveX control and the parent application.  Now I think I've determined that it only crashes if Adobe doesn't have an object to tab to; for example I can load a pdf with the GUI disabled then hit tab and results in a crash, and likewise, if I load a pdf with entry fields, then I am able to tab through all of the entry fields but near the end it again results in a crash.
                                                        We're not able to override an ActiveX method in our application language; otherwise I wouldn't have a problem doing so as outlined here, but is this issue being looked at so I may inform my customers that you're looking into it?  If there is any other information that you require please let me know.
                                                        - Dustin Buschow
                                                        • 25. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                          FYI:
                                                          I submitted this fatal error condition in Acrobat Reader to ADOBE about 1 year
                                                          ago.  After 2 formal releases and 4 or more updates, this fatal bug is not
                                                          fixed.
                                                          This bug makes the touch screen application unusable with a keyboard attached,
                                                          unless I put a plug under the TAB key to prevent crashing.
                                                          The "club" of people that have joined my bandwagon to get this bug fix have
                                                          discovered the bug existed a few versions before I reported it.  They have tried
                                                          all kinds of work-arounds.
                                                          It is really a concern, because I want to integrate Acrobat Reader into ATMS
                                                          2014.  But I don't think anyone wants to give up the TAB key in the ATMS.
                                                          Arnold Stadlin
                                                          [signature deleted by host]
                                                          • 26. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                            VMBLaOs
                                                            I have the same problem with my VB-Dot.Net-Application. If someone has a workaround or an official hint to solve the Tab-Problem please let me know
                                                            • 27. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
                                                              aucha Level 1
                                                              VMBLaOs wrote:
                                                              With VB .Net it will be not difficult to intercept message 0x1450. See for example the comments to this post
                                                              • 28. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        VMBLaOs Level 1
        Can please give my another hint how to do this in VB.Net.
        I don't know howto override the WnsProc-Sub and google only helps with C++/C# and not with Visual Basic.
        • 29. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        I'm following up to determine if Adobe or anyone else developed a fix for this AccessViolationException fatal condition when pressing the TAB key in Acrobat.
        I have confirmed that the fatal bug exists in Acrobat 10.1.0, Microsoft Visual Studio 2010, and Microsoft .NET 4, on Windows Server 2008 R2 all current updates for all products.
        Up until now, my applications with  Acrobat Reader in .NET have been Touch Screen oriented, so the users were unlikely to press the TAB key.
        This fatal bug is now a show stopper for moving my application to the desktop where there is a TAB key on the keyboard.
        Let's please fix this fatal bug in Acrobat Reader or develop a solid work around that permits the TAB key to co-exist with Acrobat Reader and Microsoft .NET Framework.
        Arnold
        • 30. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        I tested the following PreFilterMessage handler and it appears to work using VS2010, C#, .NET4, and Acrobat X Reader.
        public partial class MyAcrobatReaderCTRL : UserControl, IMessageFilter
        public MyAcrobatReaderCTRL()
        InitializeComponent();
        // Add the PreFilterMessage Handler for this control to the Parent Application
        Application.AddMessageFilter(this);
        public bool PreFilterMessage(ref Message m)
        // Block the internal Adobe's Application Fatal AccessViolationException when pressing the TAB key.
        bool bFiltered = true;
        // Adobe's Application Message = 0x1450 (5200L)
        const int WM_ACROBAT_1450 = 0x1450;
        // Apply the filter
        if (m.Msg == WM_ACROBAT_1450)
        //// Block this message or it will trigger a fatal AccessViolationException when the TAB key is pressed.
        // return true
        else
        // Other messages can pass through the filter
        bFiltered = false;
        return bFiltered;
        ** Thank you aucha for the explanation of the Acrobat message causing the bug, and Akiratorishi for pointing me to a reference for C# code that I could modify and implement (hopefully reliably).**
        Since this is still an Acrobat/Windows.NET bug, I'm not going to tag it as "Answered" until it is either fixed or until Adobe provides an affirmative work around example that they endorse.  That is - until we know that the result of this message being blocked is not causing other problems.
        With the above code, at least I can deploy my application to users with keyboards and see what happens.
        Arnold
        • 31. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        VMBLaOs Level 1
        can anybody explain how to do this in this code-snippets I got from the page vb-power.net?
        Imports System.ComponentModel
        Public Enum PDFLayoutMode
        DontCare             ' Layout laut Dokumentvorgabe
        SinglePage           ' einzelne Seite
        OneColumn            ' fortlaufende Seite
        TwoColumnLeft        ' fortlaufende Doppelseiten , ungerade Seiten links
        TwoColumnRight       ' fortlaufende Doppelseiten , ungerade Seiten rechts
        End Enum
        Public Enum PDFPageMode
        none                 ' Default-Ansicht
        bookmarks            ' Ansicht Lesezeichen
        thumbs               ' Ansicht Miniaturansicht
        End Enum
        Public Enum PDFViewMode
        Fit                  ' Komplette Seite passt vollständig ins bereitgestellte Objekt
        FitV                 ' Seitenhöhe (Vertikale) passt vollständig ins Objekt
        FitH                 ' Seitenbreite (Horizontale) passt vollständig ins Objekt
        FitB                 ' Dokumentrahmen ("Bounding Box") passt vollständig ins Objekt
        FitBV                ' Dokumentrahmenhöhe (Vertikale) passt vollständig ins Objekt
        FITBH                ' Dokumentrahmenbreite (Horizontale) passt vollständig ins Objekt
        End Enum
        Public Class PDFView
        Inherits UserControl
        Private m_PDFHost As PDFHost
        Private m_isInitialized As Boolean = False
        Private m_ShowToolBar As Boolean = True
        Private m_ShowScrollBars As Boolean = True
        Private m_LayoutMode As PDFLayoutMode = PDFLayoutMode.DontCare
        Private m_PageMode As PDFPageMode = PDFPageMode.none
        Private m_ViewMode As PDFViewMode = PDFViewMode.Fit
        #Region "Host Helper Class"
        ''' <summary>
        ''' Helper Class
        ''' </summary>
        ''' <remarks>
        ''' Diese private Klasse hostet das Acrobat ActiveX Control,
        ''' so dass es in das UserControl eingefügt werden kann.
        ''' </remarks>
        Private Class PDFHost
        Inherits AxHost
        ''' <summary>
        ''' Initialisiert den Host
        ''' </summary>
        Public Sub New(ByVal sCLSID As String)
        MyBase.New(sCLSID)
        End Sub
        ''' <summary>
        ''' Gibt ein Objekt-Verweis auf das ActiveX Control zurück
        ''' </summary>
        Public ReadOnly Property Viewer() As Object
        Get
        Try
        Return Me.GetOcx
        Catch ex As Exception
        Return Nothing
        End Try
        End Get
        End Property
        ''' <summary>
        ''' Gibt sämtliche von der Componente verwendeten Ressourcen frei.
        ''' </summary>
        Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        If Me.Viewer IsNot Nothing Then
        Me.Viewer.Dipose()
        End If
        MyBase.Dispose(disposing)
        End Sub
        End Class
        #End Region
        #Region "Initialisierungen"
        ''' <summary>
        ''' Initialisiert das UserControl
        ''' </summary>
        Public Sub New()
        MyBase.New()
        Me.InitializeComponent()
        End Sub
        If m_isInitialized Then
        m_PDFHost.Dispose()
        End If
        End Sub
        ''' <summary>
        ''' Initialisiert die Komponente.
        ''' </summary>
        ''' <remarks>
        ''' Über Late Binding wird versucht, eine Instanz des Acrobat Readers
        ''' zu erzeugen. Auf dem Zielsystem muss der Reader in der Version 7
        ''' oder höher installiert sein. Ist dies nicht der Fall, wird eine
        ''' Fehlermeldung ausgegeben.
        ''' </remarks>
        Private Sub InitializeComponent()
        Dim t As Type = Type.GetTypeFromProgID("AcroPDF.PDF")
        If t IsNot Nothing Then
        m_PDFHost = New PDFHost(t.GUID.ToString)
        DirectCast((m_PDFHost), ISupportInitialize).BeginInit()
        SuspendLayout()
        m_PDFHost.TabIndex = 0
        m_PDFHost.Visible = True
        m_PDFHost.Name = "PDFHost"
        m_PDFHost.Dock = DockStyle.Fill
        Controls.Add(m_PDFHost)
        DirectCast((m_PDFHost), ISupportInitialize).EndInit()
        ResumeLayout(False)
        PerformLayout()
        m_isInitialized = True
        Else
        m_isInitialized = False
        MessageBox.Show("Der Acrobat Reader Version 7 oder höher konnte nicht initialisiert werden." _
        & vbCrLf & "Bitte installieren Sie den Acrobat Reader in der Version 7 oder höher." _
        , "Überprüfung Acrobat Reader", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End If
        End Sub
        #End Region
        #Region "Properties"
        ''' <summary>
        ''' Die Eigenschaft liefert True zurück, wenn der Acrobat Reader
        ''' initialisiert wurde, anderenfalls False.
        ''' </summary>
        <Browsable(False)> _
        Public ReadOnly Property isInitialized() As Boolean
        Get
        Return m_isInitialized
        End Get
        End Property
        ''' <summary>
        ''' Legt den Layout Modus für das PDF-Dokument fest, oder liest diese aus.
        ''' </summary>
        <Description("Legt den Layout Modus für das PDF-Dokument fest, oder liest diese aus."), _
        Category("Darstellung"), _
        DefaultValue(GetType(PDFLayoutMode), "DontCare")> _
        Public Property LayoutMode() As PDFLayoutMode
        Get
        Return m_LayoutMode
        End Get
        Set(ByVal value As PDFLayoutMode)
        m_LayoutMode = value
        Try
        m_PDFHost.Viewer.setLayoutMode(m_LayoutMode.ToString)
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Legt den Modus für die Seitendarstellung fest,oder liest diese aus.
        ''' </summary>
        <Description("Legt den Modus für die Seitendarstellung fest,oder liest diese aus."), _
        DefaultValue(GetType(PDFPageMode), "none")> _
        Public Property PageMode() As PDFPageMode
        Get
        Return m_PageMode
        End Get
        Set(ByVal value As PDFPageMode)
        m_PageMode = value
        Try
        m_PDFHost.Viewer.setPageMode(m_PageMode.ToString)
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Bestimmt, ob die ToolBar angezeigt werden soll.
        ''' </summary>
        <Description("Bestimmt, ob die ToolBar angezeigt werden soll."), _
        Category("Layout"), _
        DefaultValue(True)> _
        Public Property ShowToolBar() As Boolean
        Get
        Return m_ShowToolBar
        End Get
        Set(ByVal value As Boolean)
        m_ShowToolBar = value
        Try
        m_PDFHost.Viewer.setShowToolbar(value)
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Bestimmt, ob die ScrollBars angezeigt werden sollen.
        ''' </summary>
        <Description("Bestimmt, ob die ScrollBars angezeigt werden sollen."), _
        Public Property ShowScrollBars() As Boolean
        Get
        Return m_ShowScrollBars
        End Get
        m_ShowScrollBars = value
        Try
        m_PDFHost.Viewer.setShowScrollbars(value)
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Legt den Modus für die Seiteneinpassung fest, oder liest diese aus.
        ''' </summary>
        <Description("Legt den Modus für die Seiteneinpassung fest, oder liest diese aus."), _
        DefaultValue(GetType(PDFViewMode), "Fit")> _
        Public Property ViewMode() As PDFViewMode
        Get
        Return m_ViewMode
        End Get
        Set(ByVal value As PDFViewMode)
        m_ViewMode = value
        Try
        m_PDFHost.Viewer.setView(m_ViewMode.ToString)
        Throw ex
        End Try
        End Set
        End Property
        #End Region
        #Region "Methoden"
        ''' <summary>
        ''' Geht im Undo-Buffer zur vorherigen Ansicht.
        ''' </summary>
        Public Sub GoBackward()
        Try
        m_PDFHost.Viewer.GoBackwardStack()
        Throw ex
        End Try
        End Sub
        Public Sub GoForward()
        Try
        m_PDFHost.Viewer.GoForwardStack()
        Throw ex
        End Try
        End Sub
        Public Sub GotoPage(ByVal PageNumber As Integer)
        Try
        m_PDFHost.Viewer.setCurrentPage(PageNumber)
        Throw ex
        End Try
        End Sub
        Public Sub GotoFirstPage()
        Try
        m_PDFHost.Viewer.GotoFirstPage()
        Throw ex
        End Try
        End Sub
        Public Sub GotoLastPage()
        Try
        m_PDFHost.Viewer.GotoLastPage()
        Throw ex
        End Try
        End Sub
        Public Sub GotoNextPage()
        Try
        m_PDFHost.Viewer.GotoNextPage()
        Throw ex
        End Try
        End Sub
        Public Sub GotoPreviousPage()
        Try
        m_PDFHost.Viewer.GotoPreviousPage()
        Throw ex
        End Try
        End Sub
        Public Function LoadFile(ByVal FileName As String) As Boolean
        Try
        Dim b As Boolean = m_PDFHost.Viewer.LoadFile(FileName)
        If b Then
        Me.ShowToolBar = m_ShowToolBar
        Me.ShowScrollBars = m_ShowScrollBars
        Me.LayoutMode = m_LayoutMode
        Me.PageMode = m_PageMode
        Me.ViewMode = m_ViewMode
        End If
        Return b
        Throw ex
        End Try
        End Function
        Public Sub PrintWithDialog()
        Try
        m_PDFHost.Viewer.PrintWithDialog()
        Throw ex
        End Try
        End Sub
        Public Sub Zoom(ByVal Percent As Single)
        Try
        m_PDFHost.Viewer.setZoom(Percent)
        Throw ex
        End Try
        End Sub
        #End Region
        End Class
        • 32. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        Why not download the Acrobat SDK and read the documentation?
        • 33. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        DBuschow Level 1
        Irosenth,
        I've read the applicable documentation for using the AcroPDF ActiveX control.  Am I mistaken that the source code for the ActiveX control is available in the Acrobat SDK, and I can resolve the many issues that it has on my own, distribute it to thousands of users royalty free?
        Also, I don't quite understand the reasons for your passive-aggressive comment.  Why not just fix the problem in your ActiveX control?  It's been almost three major revisions since these issues have been reported.
        • 34. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        There is no source code for the ActiveX control available.
        The ActiveX is only a "wrapper" around Reader and/or Acrobat - it does
        NOTHING w/o one of those installed on the user's computer.
        • 35. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        DBuschow Level 1
        Irosenth,
        I completely understand that ActiveX controls are wrappers, and simply call API calls offered by the reader.  But are you suggesting that I write my own ActiveX control "wrapper" and distribute it to my clients- all to solve two issues?  The language that we're using does not allow us to override methods within the ActiveX control like VB.NET or C#, so none of these work-arounds have worked for me.
        So rather than relying on work-arounds for the past few years, I just want to know, when will these bugs finally be fixed by Adobe?  I have a few users that close (and dispose) the control which causes my application to hang, while all of my users can't tab out of the control because it also causes it to hang.
        I can't get any support from you, Adobe.  I've tried to get support contracts, and you've refused- multiple times- to support Adobe Reader's ActiveX control.  Regardless, it is distributed with either business package, Reader, Acrobat, etc., so it's hard for me get anything reliable from you when you simple say you don't support Reader, or when I then submit a ticket and it gets closed without any response.  I open another ticket and the same ensues.
        When can these things be fixed?
        - Dustin
        • 36. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        Ale Bernardi - BBros
        Thankyou all for sharing your experience.
        I've been able to fix the application hang by mixing the vb code provided by VMBLaOs with c# code provided by AccessViolationException.
        You can compile and use your own PDFView class (Translated in english ) adding this code to your application.
        DontCare             ' Layout according to the document specification
        SinglePage           ' Single page
        OneColumn            ' Continuous page
        TwoColumnLeft        ' Continuous double pages, odd pages left
        TwoColumnRight       ' Continuous double pages, odd pages right
        End Enum
        none                 ' Default view
        bookmarks            ' View bookmarks
        thumbs               ' View thumbs
        End Enum
        Fit                  ' Entire page fits completely into the provided object
        FitV                 ' Page height (vertical) fits completely into the object
        FitH                 ' Page width (horizontal) fits completely into the object
        FitB                 ' Document frame ("bounding box") fits completely into the object
        FitBV                ' Document frame height (vertical) fits completely into the object
        FITBH                ' Document frame width (horizontal) fits completely into the object
        End Enum
        Implements IMessageFilter
        #Region " Host Helper Class "
        ''' <summary>
        ''' Helper Class
        ''' </summary>
        ''' <remarks>
        ''' This private class hosts the Acrobat ActiveX control so that it can be inserted into the UserControl.
        ''' </remarks>
        Inherits AxHost
        ''' <summary>
        ''' Initializes the host
        ''' </summary>
        MyBase.New(sCLSID)
        End Sub
        ''' <summary>
        ''' Returns an object reference to the ActiveX control
        ''' </summary>
        Get
        Try
        Return Me.GetOcx
        Return Nothing
        End Try
        End Get
        End Property
        ''' <summary>
        ''' Releases all resources used by the component
        ''' </summary>
        Me.Viewer.Dipose()
        End If
        End Sub
        End Class
        #End Region
        #Region " Initialization "
        ''' <summary>
        ''' Initializes UserControl
        ''' </summary>
        Public Sub New()
        MyBase.New()
        Application.AddMessageFilter(Me)
        End Sub
        m_PDFHost.Dispose()
        End If
        End Sub
        ''' <summary>
        ''' Initialize components.
        ''' </summary>
        ''' <remarks>
        ''' Late binding is trying to create an instance of the Acrobat Reader. On the target system must the reader version 7 or later be installed. If this is not the case, an error message will be shown.
        ''' </remarks>
        SuspendLayout()
        ResumeLayout(False)
        PerformLayout()
        Else
        MessageBox.Show("The Acrobat Reader version 7 or higher could not be initialized." _
        & vbCrLf & "Please install Acrobat Reader version 7 or higher." _
        , "Initializiation of Acrobat Reader component", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End If
        End Sub
        #End Region
        #Region " Properties "
        ''' <summary>
        ''' Property returns the Acrobat Reader initialization state.
        ''' </summary>
        Get
        End Get
        End Property
        ''' <summary>
        ''' Gets or sets the layout mode for the PDF document.
        ''' </summary>
        <Description("Gets or sets the layout mode for the PDF document."), _
        Get
        Return m_LayoutMode
        End Get
        Try
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Gets or sets the mode for the page view.
        ''' </summary>
        <Description("Gets or sets the mode for the page view."), _
        Get
        Return m_PageMode
        End Get
        m_PageMode = value
        Try
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Determines whether the toolbar should appear.
        ''' </summary>
        <Description("Determines whether the toolbar should appear."), _
        Get
        End Get
        Try
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Determines whether to display the ScrollBars.
        ''' </summary>
        <Description("Determines whether to display the ScrollBars."), _
        Get
        End Get
        Try
        Throw ex
        End Try
        End Set
        End Property
        ''' <summary>
        ''' Gets or sets the mode for the page fit.
        ''' </summary>
        <Description("Gets or sets the mode for the page fit."), _
        Get
        Return m_ViewMode
        End Get
        m_ViewMode = value
        Try
        Throw ex
        End Try
        End Set
        End Property
        #End Region
        #Region " Methods "
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        Try
        If b Then
        End If
        Return b
        Throw ex
        End Try
        End Function
        Try
        Throw ex
        End Try
        End Sub
        Try
        Throw ex
        End Try
        End Sub
        #End Region
        Public Function PreFilterMessage(ByRef m As System.Windows.Forms.Message) As Boolean Implements System.Windows.Forms.IMessageFilter.PreFilterMessage
        'Block the internal Adobe's Application Fatal AccessViolationException when pressing the TAB key.
        Dim bFiltered As Boolean = True
        'Adobe's Application Message
        Const WM_ACROBAT_1450 As Integer = 5200 '0x1450
        'Apply the filter
        If m.Msg = WM_ACROBAT_1450 Then
        'Block this message or it will trigger a fatal AccessViolationException when the TAB key is pressed
        bFiltered = True
        Else
        'Other messages can pass through the filter
        bFiltered = False
        End If
        Return bFiltered
        End Function
        End Class
        • 38. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        Ale Bernardi - BBros Level 1
        Look for "Dipose" and replace it with "Dispose" in order to let the viewer dispose.
        • 39. Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
        james.g.taylor
        I'm working on a legacy vb6 application that experiences the same issue with Reader 10.1.
        Has anyone come up with a work around that can be applied in vb6?
        Thanks ahead of time.
        JT
        1 2 Previous Next
