Julie
Normally when you click in a paragraph the stylename will
display in mixed case in the toolbar. That indicates RH has found
the style in the CSS and is applying it. If you delete the style,
the stylename will appears in CAPS indicating RH knows a style
should be applied but cannot find it. Effectively that is going to
be the same as no style so the text will display in your users'
browsers in whatever font is the default. That will likely conflict
with your paragraphs that do have a style and look like a dog's
dinner.
Once you have gone through your document though, there should
be no such references and you can safely delete the styles.
Nonetheless make a copy of the CSS first, just in case.
The other way is to apply whatever CSS you normally use and
then work through your document looking for the styles in caps and
applying your styles there.
Does that cover it?
A useful way to import is to import into a clean project and
tidy up there. Once done, you can import the clean files into your
project. The advantage of this method is if it goes wrong, it is
quick and easy to back out.You just trash that project and start
over.
