I'm using the code below since a while on a ColdFusion hosting on Windows platform. Now I try to install on a Linux server and I get this error (on working code):
Object Instantiation Exception.An exception occurred when instantiating a Java object. The class must not be an interface or an abstract class. Error: ''.
Here is the code extract. The error occurs on the marked line.
Anybody knows how to solve this?
<cfscript>
prefix = ucase(left(name,find(".properties",name)-1));
languages = listAppend(languages,prefix);
// these objects enable getResourceBundle method to load the properties files:
rb = createObject("java", "java.util.PropertyResourceBundle");
fis = createObject("java", "java.io.FileInputStream");
if( not isDefined("application.rb_#prefix#")) {
fis.init(application.translationpath&prefix&'.properties');
rb.init(variables.fis);
"application.rb_#prefix#" = rb;
fis.close();
</cfscript>
I think the problem isn't the line fis = createObject("java", "java.io.FileInputStream");, but the line after that. It should be an assignment of the form a=b. Something like this should work:
<cfscript>
// fis and rb enable getResourceBundle method to load the properties files:
variables.fis = createObject("java", "java.io.FileInputStream").init(application.translationpath&prefix&'.properties');
variables.rb = createObject("java", "java.util.PropertyResourceBundle").init(variables.fis);
"application.rb_#prefix#" = variables.rb;
variables.fis.close();
</cfscript>
In fact, this is even more efficient, as you will only need to create the objects when isDefined() returns true.
I trief with your suggestion, but still the error.
Object Instantiation Exception. | |
An exception occurred when instantiating a Java object. The class must not be an interface or an abstract class. Error: ''. | |
The error occurred in /var/opt/coldfusion8/wwwroot/hosts/www.backup.habimat.be/Application.cfm: line 46 | |
44 : // fis and rb enable getResourceBundle method to load the properties files: 45 : if (not isDefined("application.rb_#prefix#")) { 46 : variables.fis = createObject("java", "java.io.FileInputStream").init(application.translationpath&prefix&'.properties '); 47 : variables.rb = createObject("java", "java.util.PropertyResourceBundle").init(variables.fis); 48 : "application.rb_#prefix#" = variables.rb; |
Make sure this line -- neater without the extra space at the end -- represents a string that represents the full path to a properties file. What happens when you replace it with
"#application.translationpath&prefix&'.properties'#"
Still the same 😞 I tried just removing the trailing space and adding the # signs.
44 : // fis and rb enable getResourceBundle method to load the properties files: 45 : if (not isDefined("application.rb_#prefix#")) { 46 : variables.fis = createObject("java", "java.io.FileInputStream").init(#application.translationpath#&#prefix#&'.properties'); 47 : variables.rb = createObject("java", "java.util.PropertyResourceBundle").init(variables.fis); 48 : "application.rb_#prefix#" = variables.rb; |
OK it works...the most stupid Windows <> Linux mistake...
tried to load NL.properties while it should be nl.properties.
Thanks for the help!
