Good evening all,
I have this:
<cfinput type="datefield" name="startdate" value="#dateformat(Now(), 'mm/dd/yyyy')#">
<cfinput type="datefield" name="nextdate" value="#dateformat(Now() +90, 'mm/dd/yyyy')#" readonly="yes">
I want to advance "nextdate" by 90 days when "startdate" is changed.
Use cfinput's bind attribute, for example
<script type="text/javascript">
/* add 90 days to a given date */
addDays = function(dateStr) {
var newdate = (new Date(dateStr)).add('d',90);
var days = newdate.getDate();
var months = newdate.getMonth()+1;
var year = newdate.getFullYear();
/* the datefield widget requires 2 digits to display*/
if(days < 10) days = '0'+days;
if(months < 10) months = '0'+months;
return months + "/" + days + "/" + year;
</script>
<cfform name="dateForm" id="dateForm">
<cfinput type="d
</script>
<cfinput type="datefield" name="nextdate" bind="javascript:addDays({dateForm:startdate})" readonly="yes">
</cfform>
BKBK,
Thanks. This is what I was looking for. I made a slight change. I changed the second <cfinput type="text">, I left it readonly so that users cannot change the 90 day date.
<cfinput type="text" name="nextdate" bind="javascript:addDays({dateForm:startdate})" readonly="yes">
</cfform>
Thanks again,
djkhalif
BKBK,
I couldn't get it to work with flash format.
THanks,
djkhalif
You're right. Flash doesn't wanna play. I'll have a look.
I have been returning to the subject. I am still looking for a neat way to do dateAdd in Actionscript, as Coldfusion doesn't allow new Date(). (Coldfusion's flash forms don't allow you to create objects using the new keyword).
In the meantime, why don't you post the "flash" version of your original question in the Rich Forms forum ? It's sure to attract new suggestions.
Yes, from what I recall there is not much in the way of date functions in Flex 1.5. But one nice thing is you can get away with some of the keywords like "new" using functions. So you could try and roll your own. I do not know if the date math works in all scenarios, but here is a quick example. Note, I cheated and used the internal mx.formatters.DateFormatter() class.
<cfform name="dateForm" id="dateForm" format="flash">
<cfformitem type="script">
function addDays(baseDate:Date, numOfDays:Number)
var newDate = new Date();
// calculate the days to add in milliseconds
var daysToAdd = numOfDays * (24*60*60*1000);
// add the days to the starting date
newDate.setTime(baseDate.getTime() + daysToAdd);
// format the new date as a string
var formatter = new mx.formatters.DateFormatter();
formatter.formatString = "MM/DD/YYYY";
return formatter.format(newDate);
</cfformitem>
<cfinput type="datefield" name="startdate" value="#dateformat(Now(), 'mm/dd/yyyy')#" />
<cfinput type="text" name="nextdate" bind="{addDays(startdate.selectedDate, 90)}" readonly="yes" />
</cfform>
@ -==cfSearching==-
Thanks for the new breakthough.
@Djkhalif
Now you're spoilt for choice.
function addDays2(numberOfDays,dateObject) {
// convert date to milliseconds
var dateValue = dateObject.valueOf();
var newDate = new Date(dateValue+numberOfDays*24*60*60*1000);
// remember getMonth returns 0 to 11 in Actionscript
return (newDate.getMonth()+1) + "/" + newDate.getDate() + "/" + newDate.getFullYear();
</cfformitem>
<cfinput type="text" name="nextdate" bind="{addDays2(90,startdate.selectedDate)}" readonly="yes" />
</cfform>
Haha
var newDate = new
Date(dateValue+numberOfDays2460601000);
Nice one. I suspected the constructor might accept milliseconds. But did not see it the documentation I found (granted it was old).
-Leigh
BKBK and cfSearching,
I apologize for getting back to so late. cfSearching example works.
djkhalif
