I'm writing a neat little image editing tool for image uploadds, but I need to constrain the images to a 4:3 ratio.... I can get the images, dimeansions all that etc no problems, but, with CFMX, how do I determine the ratio between 2 numbers?? looping trough division statements looking for integers and then comapring to see where the lowest is found seems REALLY REALLY messy...
is there a better way?
-thanks
-sean
if (height / width == 3 / 4)
accept;
else
reject;
Your question is not clear. What division statements do you have to loop through? Why do you have to look for integers?
to find a ratio you need to find the highest common factor [?] that both dimensions [height & width] are divisible by i.e. 640x480 highest common factor is 160 divide them both is 4:3 .... [I hope I am using the math terms right]
-sean
How are you going to use this number once you have it?
basically all I need to do is determine if the uploaded image dimensions are in a 4:3 ratio, [640x480, 800x600, etc.] so I can resize it without distortion or reject the image.
-sean
UPDATE:
hmmm, if I divide the first dimension [width] by 4 then multiply the result by 3 that result should equal the provided image's height to equal a 4:3 ratio.
Think I just answered my own [3rd grade math] question.
-sean
accept;
else
reject;
I think jochemd's answer was closest to the mark I am looking for here....
height/width = 0.75 and I want to give a litlle bit of leeway here say up to 1% in any dimension so....
ratio = (height / width);
if ( (ratio lte 0.76) and (ratio gte 0.74)) {
do;
}else{
or do not;
//there is no try.
that gives me approximately 10 pixel leeway if someone were to upload a 1024x768 image.[i.e. they could upload a 1034x770 image and it would still pass muster.
-thanks guys
-sean
That's actually what I meant by "Floating-point arithmetic is, in general, not exact". Your earlier attempt and indeed Jochemd's didn't take account of that.
Now to something else. A deviation of 0.76 or 0.74 from 3/4 isn't 1%. It is 0.01 of 0.75, which is approximately 1.33%.
If you wish to have a 1% tolerance from 3/4, then you have to do something like
ratio = height/width;
if (abs(4*ratio/3 -1) LT 0.01) {
do;
}else{
or do not;
//there is no try.
Like I said "about" - "up to" not exactly 1% cause users are not going to get it perfect every time
though, not sure about your 1.33% comment, by dividing height/width, we are finding what % height is of width, so by saying "is it 75%" then giving it a leeway of "1" either way, is exactly 1%..... unless I am missing somehting.
either way - no big deal, it's supposed to be somewhat fuzzy.
-sean
@Sean69
No misunderstanding there. That's what I meant, too.
missing somehting.
What you're measuring isn't height or width, but ratio. As the variable under consideration is the aspect ratio 3:4, a leeway of 1 either way is therefore 1 out of 75. That is around 1.33%.
When you say 1%, it implies 1% of 0.75, which is 0.0075. In other words, the condition for a value of the aspect ratio to be within 1% of 0.75 is: abs(ratio - 0.75)/0.75 <= 0.01.
Aspect Ratio is a dimensionless quantity. That is, the unit of length(inches, metres, centimetres) in the height will cancel out that in the width. This imples that a deviation from the ratio remains the same as you scale up, say, from 800x600 to 1024x768. Therefore, your solution, abs(ratio - 0.75) <= 0.01, is as good as any.
I agree. Main thing is, your problem has been solved.
@Sean69
@Jochemd
accept;
else
reject;
Not quite. When you divide by integers, you're into floating-point arithmetic.
Floating-point arithmetic is, in general, not exact. To avoid truncation errors, keep the logic within the set of integers, something like
if (4*height EQ 3*width)
else
