I was wondering if I concatenate strings within the query I write in a <cfquery> tag with dbtype="query"?
I want to do something similar to the following:
<cfquery name="a_query" dbtype="query">
SELECT
('$ ' + TotalProfit) AS TotalProfit2
FROM SomeCachedQuery
</cfquery>
I can do this if the query is run on the SQL server, but not with the cached query.If this is not possible, is there some code I can wirte that does the same thing?
Jason
Does this actually work for you? It doesn't for me,
unless I case TotalProfit to be a varchar, first.
As Adam said, you need to cast the value to a varchar first. Either in the original query or within the QoQ:
SELECT '$ '+ CAST(TotalProfit AS VARCHAR) AS TotalProfit2
FROM SomeQuery
However, you could just use NumberFormat() in your output. Unless there is some reason you need to do this in a QoQ..
#NumberFormat(SomeQuery.TotalProfit, "$-9999999.00")#
Since you can do it in the original sql, you should. If you want to do it in ColdFusion, look at the query functions such as queryaddcolumn and querysetcell.
SELECT
</cfquery>
That is quite possible. In fact, it is so common you will come across it all over the place.
Just to confirm: what you're trying to do should be something like
<cfquery name="SomeQuery" datasource="someDSN">
SELECT TotalProfit
FROM someTable
</cfquery>
SELECT ('$ ' + TotalProfit) AS TotalProfit2
FROM SomeQuery
</cfquery>
FROM SomeQuery
</cfquery>
Does this actually work for you? It doesn't for me, unless I case TotalProfit to be a varchar, first.
Adam
FROM SomeQuery
FROM SomeQuery
</cfquery>Does this actually work for you? It doesn't for me, unless I case TotalProfit to be a varchar, first.
Adam
Yes, Adam, it works for me. But then, I take it for granted TotalProfit is of type char or varchar. The title and Jason_y's opening phrase("I was wondering if I concatenate strings") give that impression.
FROM SomeQuery
Well... sure. To concatenate one string ("$") to something else, both are going to have to end up being strings at some stage. But it seems unlikely that a column that:
a) is having a dollar-sign applied to the beginning of its value;
b) is called "TotalProfit";
is going to be a string to start with.
Still... stranger things have happened, I guess.
Adam
If the concatonation is static text to a db field, a simple way to do it is in the output, not in the query.
Hi All,
Thanks for your help. The TotalProfit column in my original query is a numeric field and casting it in the QofQ did the trick. The reason I wanted to add the dollar sign in the query instead of a <cfouput> is I wanted to use the result of the query and bind it to a cfgrid (HTML version). This tag had attributes that allow you to add numberformat / dollarformat, but they're only for the Flash version of the cfgrid. It was unavailable for the HTML version. I considered using the Flash version, but this version did not allow you to bind data to the grid. I wanted the page navigation / column sorting that binding allows.
I'm not too sure why cfgrid have different attributes for different grid types. I kinda wish the binding and the number format both exist at the same time.
Jason
