4 Replies Latest reply on Jul 11, 2008 3:58 AM by RolyRoger
    Need help establishing a connection within DW to SQL2005 database on godaddy.com
    Mythic
      i have the connection string setup within my connections file and if i
      handcode the displaying of my recordset, the page works once uploaded.. but
      im use to having the ability to make my selection of tables and stored
      procedures from the dreamweaver windows..
      Right now if i try to open the Bindings list i get an error HTTP Error
      Code 400 Bad Request
      with that i cant select my column names and bind them to the page..
      Has anyone been able to make a connection to the SQL database and use these
      features withing DW?
      I really dont have the time to ref my table and column layouts to hand code
      every field i want displayed on the page and such.. any ideas or suggestions
      would be great...
      Also, when i upload the pages, they work fine, so i know my connection is
      working, but not locally. If i setup a Custom Connection String that doesnt
      work either..
      ASP, SQL2005, DW8 VBScript, Access
        • 1. Re: Need help establishing a connection within DW to SQL2005 database on godaddy.com
          StormyCrow
          Yes! I've been successfully able to connect to GoDaddy MySQL database. But only through lots of trial and error and only through help with customer support. First off, what kind of server do you have with them? Is it a shared hosting or is it virtual dedicated or dedicated. The method is hugely different with each one. I'm checking this regularly because I'm trying to get a question answered, so let me know and I'll try to share the knowledge.
          • 2. Re: Need help establishing a connection within DW to SQL2005 database on godaddy.com
            Mythic
            Its a Windows Shared Hosting plan...
            my connection works great when i upload to the server, so i know that the
            communication is setup properly, but i want to be able to connect to the
            tables to be able to bind and setup my procedures without havign to hand
            code it all..
            Im use to using MSAccess locally and remotely so setting up the DSN locally
            so i can configure the pages and since the setup is the same on the server
            once uploaded everything works fine..
            but now with this setup this i can only see once i have uploaded the pages
            to the site..
            ASP, SQL2005, DW8 VBScript, Visual Studio 2005, Visual Studio 2008
            "StormyCrow" <webforumsuser@macromedia.com> wrote in message
            news:g55djp$fjl$1@forums.macromedia.com...
            > only
            > support.
            > hosting or
            > each
            > answered,
            • 3. Re: Need help establishing a connection within DW to SQL2005 database on godaddy.com
              doug30
              I was able to connect to the MySQL database by going to my godaddy database list in the hosting control center. I picked the database I wanted and clicked on the "pencil" to view the details of the database. Then I clicked on the configuration icon. I highlighted the entire box of ODBC 3.51 settings and copied them to the connection string. I was able to connect and to test. it shows all tables, but now when I go to live view I get an error message that says "Microsoft VBScript compilation error 800a0408 invalid character"
