the following code writes to an xml document. the problem is it writes everything to the same line. when i go to parse the xml doc i get an error. i would like to modify this code to write each node to it own line.
before code my xml files looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<messageList>
<message>
<sender>bob</sender>
<creator>tom</creator>
</message>
</messagelist>
<cfset xApps = XmlParse(cfhttp.FileContent)>
<cfset arrayInsertAt(xApps.messageList.xmlChildren,1,xmlElemNew(xApps,'message'))>
<cfset xApps.messageList.message[1].sender = xmlElemNew(xApps,'sender')>
<cfset xApps.messageList.message[1].sender.xmlText = "#send#">
<cfset xApps.messageList.message[1].creator = xmlElemNew(xApps,'creator')>
<cfset xApps.messageList.message[1].creator.xmlText = "#creat#">
<cffile action="write" file="C:\temp\messages.xml"
output=#toString(xApps)#>
my code does this to the xml file which does not parse.
<messageList>
<message><sender>Bill</sender><creator>Dave</creator></message><message>
<sender>winter</sender>
<creator>winter</creator>
</message>
</messagelist>
What is tyring to parse this?
XML is supposed to be white space agnostic and not care how the file is spaced.
Your version is a little hard for humans, but a parser should not care.
not following the humans thing but here goes. i grap an exisiting doc and parse it in a CFC
<cfhttp url="messages.xml " method="GET">
i grab data from a form and insert it into the xml doc. that works fine. when i try to modify the xml a second time
it gives me a parsing error. if i update the newly written data on the xml doc manually, placing each node on its own line the xml doc will update. this is how i know my data is correct but formatting is not
Show us the code. All of it.
here is the code for the cfc object. the form data is in the variable. this cfc gets called each time the form gets filled out and changes need to be made to the xml doc
<cfcomponent displayname="updatexml" hint="">
<cfscript>
//get user info needed struct name , var name
objUser = createObject("component", request.rootPath&".user");
objUser.getUserProperty("frmSender", "Sender");
objUser.getUserProperty("frmRequester", "creator");
objUser.getUserProperty("frmStartDate", "StartDate");
objUser.getUserProperty("frmStartTime", "StartTime");
objUser.getUserProperty("frmEndDate", "EndDate");
objUser.getUserProperty("frmEndTime", "EndTime");
objUser.getUserProperty("frmMessage", "messageText");
objUser.getUserProperty("selectOptionList", "OptionList");
// objUser.getUserProperty("frmexthome", "ehome");
// objUser.getUserProperty("frmextdatawarehouse", "extdata");
</cfscript>
<cffunction name="newmessage" hint="adds new message to messages.xml . Data comes from addUserMessage.cfm, returns boolean" output="yes" access="public" returntype="string">
<!--- <cffunction name="newmessage" access="remote" returntype="xml" output="false"> --->
<cfscript>
var send = "#request.Sender#";
var creat = "#request.creator#";
var sdate = "#request.StartDate#";
var edate = "#request.EndDate#";
var mess = "#request.messageText#";
var opt = "#request.OptionList#";
var stime = "#request.StartTime#";
var etime = "#request.EndTime#";
</cfscript>
<!--- convert time to 24 hours --->
<cfset StartTime=#stime#>
<cfset EndTime=#etime#>
<!--- add date and time together to update xml doc --->
<cfset startdatetime = DateFormat("#sdate#" , "yyyymmdd" )& "" & TimeFormat("#StartTime#", "Hhmm")>
<cfset enddatetime = DateFormat("#edate#" , "yyyymmdd" ) & "" & TimeFormat("#EndTime#", "Hhmm")>
<!--- place to contents of checkbox choices into an array --->
<cfset myArrayList = ListToArray(opt)>
<!--- <cfdump var=#myArrayList#/></p>
<cfdump var=#opt#/></p> --->
<!--- get reference to xml page --->
<cfhttp url="messages.xml" method="GET">
<!--- parse xml page --->
<cfset today = dateFormat(now(), "mm/dd/yyyy")>
<!--- <cfset xApps = XmlParse("request.browserPath&\message_dummy.xml")> --->
<!--- set carriage return var --->
<cfset variables.CrLf = Chr(13) & Chr(10)>
<!-- set new values in array --->
<cfset xApps.messageList.message[1].dateCreated = xmlElemNew(xApps,'dateCreated')>
<cfset xApps.messageList.message[1].dateCreated.xmlText = "#today#">
<cfset xApps.messageList.message[1].startDate = xmlElemNew(xApps,'startDate')>
<cfset xApps.messageList.message[1].startDate.xmlText = "#startdatetime#">
<cfset xApps.messageList.message[1].endDate = xmlElemNew(xApps,'endDate')>
<cfset xApps.messageList.message[1].endDate.xmlText = "#enddatetime#">
<cfset xApps.messageList.message[1].messageText = xmlElemNew(xApps,'messageText')>
<cfset xApps.messageList.message[1].messageText.xmlText = "#mess#">
<!--- loop through checkbox options and update xml file --->
<cfloop from="1" to="#arraylen(myArrayList)#" index="j">
<cfset arrayInsertAt(xApps.messageList.message.xmlChildren, j,xmlElemNew(xApps,'forPage'))>
<!--- <cfset xApps.messageList.message[1].forPage
<cfset tempvar= #myArrayList
<cfset tempvar2= #trim(tempvar)#>
</cfloop>
<!---<cfdump var="#xApps#"> testing --->
<!---write new values to xml page--->
<cffile action="write" file="/webdocs/intranet/cfapps/userMessageDev/userMessage/messages.xml"
<!--- Return the XML code to the browser --->
<!--- (or whatever program initiated this request) --->
<!--- <CFCONTENT
TYPE="text/plain"
RESET="Yes"><CFOUTPUT>#ToString(xApps)#</CFOUTPUT> --->
<cfreturn xApps />
</cffunction>
</cfcomponent>
Add charset attributes to all cfhttp and cffile calls. For the rest nothing obvious, I'll try to run it later.
A human looking at an XML document generally cares about line breaks and nested tag indention for ease of readability.
A computer shouldn't. The XML specification indicates that parsers are not supposed to care.
got it. i am a db guy and used to seeing things in rows and columns. this
is my first web app. there must be something i am missing. when i reformat
the data i have just sent to them xml doc by open the doc in dreamweaver
and pressing enter after each node and saving i am able to parse and update
doc
thanks
Message was edited by jochemd to remove an email address
<messageList><message><sender>Bill</sender><creator>Dave</creator></message><message>
<creator>winter</creator></message>
</messagelist>
Is this an actual copy from your output, or did you type this in? If the former, then the problem is the <messageList>...</messagelist> tags. While the XML specification indicates it is to be white space agnostic, it is also to be case sensitive. Thus the <messageList> with an upper case 'L" and </messagelist> with a lower case 'l" are not matching tags.
Upon fixing the case issue the following code worked just as expected on my system.
<cfsavecontent variable="xml"><?xml version="1.0" encoding="UTF-8"?>
<messageList>
</message>
</messageList></cfsavecontent>
<cfset xApps = xmlParse(xml)>
If the case of the "L" was just a typo in the forum post, then the problem might be with actual data? Again is this the actual output or is a simplified example where the actual output might contain special characters such as ampersand "&" characters?
If this is the case, you may not be able to just cut and paste the XML from a browser and parse it.
this is a simplified example . i will check the xml doc on monday for the L vs l but i believe that is also a typo on my part. i appreicate your time..enjoy the holiday
i cleaned up the data on my xml file to simplify it and make it easier to debug. I also update code to include charset value. my xml doc is updating correctly now. thank you for your time and help with this issue
<cfhttp url="messages.xml" method="GET" charset = "UTF-8">
