1 Reply Latest reply: Dec 3, 2009 4:09 AM by sn1ckers RSS
    How to get amf headers?
    sn1ckers Community Member
      Hi
      I have set up communication between Actionscript and .NET WCF using amf. And the communication has worked fine using NetConnection. I have sent and recevied data in both directions. And sending headers from actionscript is no problem but when i send headers from WCF to actionscript I cant find a way to extract/find the header.
      I have monitored the call using charles and there I can se that the header is sent back with the call from WCF.
      I found this in the AMF specification, but how do i do it?
      To handle an AMF context header a suitable method needs to be available, matching the header name. NetConnection is now a sealed type so either it must be subclassed or an object with a suitable implementation needs to be set for the NetConnection client property.
      Thanks in advance
        • 1. Re: How to get amf headers?
          I solved it at posting my findings here.
          To get the header I had to send in a Object to the client parameter on NetConnection like the code below:
          public class UsingNetConnectionWithHeader
               public function UsingNetConnectionWithHeader
                    netCon = new NetConnection();
                    netCon.addEventListener(NetStatusEvent.NET_STATUS, connectionHandler);
                    netCon.connect(remotingGateway);
                    netCon.client = new CustomClient();
                    netCon.call("Method", new Responder(successfulResult, erroneousResult),param1,param2...);
               public function connectionHandler(ev:NetStatusEvent):void
                    if(ev.info.code == "NetConnection.Call.Failed")
                         trace("Call failed");
               public function successfulResult(obj:Object):void
                    trace("Call Successful");
               function erroneousResult(obj:Object):void
                   trace("Call Failed");
          public class CustomClient
               public function CustomHeader(content:String):void
                    trace("Got header with content:" + content);
          To get this to work the custom header name must be CustomHeader.
