RH HTML 8.0.2.208
We are converting from HTML Help to WebHelp. We are going to be merging the projects (thank you Mr. Grainge for your articles - very helpful!).
Current external URLs in topics are: projectname.chm::/topicname.htm
I assume that the external URLs will now have to be referenced as: X:/helpfolder/startpage.htm#mergedprojects/child_project/target_topic_1.htm
Am I correct in that assumption?
Thanks in advance.
Both are correct.
X:/helpfolder/startpage.htm#mergedprojects/child_project/target_topic_1.htm will open the topic with the nav pane and toolbar.
X:/helpfolder/mergedprojects/child_project/target_topic_1.htm will open the topic without the nav pane and toolbar.
Also both of those will only work if everyone has the same drive mapping. Can you guarantee that? Might be better to use the server name.
Note that RH creates the path as mergedProjects (capital P) and that will be important if you server is U
...Copy link to clipboard
Not quite. Try X:/helpfolder/mergedprojects/child_project/target_topic_1.htm assuming the merged projects are in the X:/helpfolder/ folder.
Both are correct.
Note that RH creates the path as mergedProjects (capital P) and that will be important if you server is Unix based.
Follow me @petergrainge
Peter,
Thank you for your suggestion.
Mark
Date: Wed, 2 Dec 2009 07:52:09 -0700
To: steelcasemark@hotmail.com
Subject: RH HTML 8.0.2.208 - Convert HTMLHelp to WebHelp - External URLs within topics
Both are correct.
See http://www.grainge.org for RoboHelp and Authoring tips
Follow me http://twitter.com/petergrainge
Thank you for the suggestion.
Date: Wed, 2 Dec 2009 07:46:09 -0700
Read the http://notcolin.wordpress.com/ for a tips, tricks and musings on the Technical Communication Suite products.
Follow the RoboColum(n) on http://twitter.com/robocolumn
Thank you all!
