I've become accustomed to editing screenshots that are already embedded in the help topics...just right-click Edit, and the default editor had an icon so that I could change/obscure file names & login info--worked great!
Then I rebuilt my machine with Windows 7. The two graphics editor products no longer display, but I discovered RoboScreenCapture could do the same thing (basically just pull some snippets to overlay the GUI fields.
Well, now I have red boxes for the screens I have edited. I can see them (they have 26 KB size). I've tried to insert them and they even display as an empty red square in the prreview of the image dialog box. However, if I doubleclick the imagein the Project Manager, it opens & displays "just fine" in the image properties dialog. How do I fix this?
Also, Windows 7 seems to disable the main RH project (pods & Design View) if I have the RH Help window open. Any one else notice?
I've rebooted. Is there some kind of setting to make RH and Windows 7 like each other?
You don't say if you have applied the 801 patch, it is important for Windows 7.
I've seen similar issues without Windows 7 being involved. Usually hacking around a bit by deleting the image from the project and sometimes also in Windows Explorer and then starting over fixes it.
When you say the two graphics products no longer display, do you mean they are plain not working or that they are no longer playing with RH?
Follow me @petergrainge
Hey Peter!
AH! I need to reload the 801 update! Thanks! (I have 2 machines, my laptop with XP, my desktop with Win 7).
Looks like "the default editor" for RoboHelp differs, depending on which OS it's loaded on! In XP, the default editor is Windows Picture and Fax Viewer. In Win 7...it seems to be "undefined." I've defined it to be MS Paint (Tools>Options>Associations tab) and I'm back in business!
RH on Win 7 obscures what's going on with the fileseven using the RoboScreenCaptureas though there's a buffer storage somewhere in either Win 7 or RH 8 that is holding a secondary copy of a graphics file.
Easy way to edit a graphic
RH on XP:
Right-click graphic (.jpg or .gif) in Design view of a topic
Select Edit
Graphic opens in Windows Picture and Fax Viewer.
Click Ctrl+E to "close WPFV and open the graphic in MS Paint
Change graphic
Click File>Save
Edited graphic redisplays in topic
Right-click graphic and select Reset size
RH on Win7
Select Edit
Graphic opens in MS Paint (after you set up associations! Else, nothing happens)
Change graphic
Click File>Save
