I am trying to upgrade 7.x processes to livecycle ES.
Whenever I try to run the Process Upgrade Tool, it shows "No Upgrade definition known"
I am able to see the upgrade folder under workbench installation folder. I have also registered the mappings location as mentioned in the help document.
Can anyone advise on this?
Nith
Total Likes
Are the upgrade definition files actually in the folder that you registered?
Total Likes
Yes, the files are there under upgrade/mappings folder.
I explain the task I did:
1. Installed LiveCycle workbench ES with upgrade from 7.x option selected
2. Executed Configuration Manager with upgrade from 7.x option selected
3. Workbench->Windows->Preferences->Upgrade Tool -> (browse location) apply
3. Imported a process created in LiveCycle 7.x
4. Right click and selected "Upgrade to LiveCycle ES"
5. Error at this time (no upgrade definition known)
One question: Do we need the livecycle 7.x in running state as well?
Thanks & Regards,
Nith
Total Likes
After installing the 7.x QPACS (manually) it worked. I thought the 7.x QPACS are automatically installed if we run the configuration manager.
Nith
Total Likes
Glad you solved the problem. I added a note to the LiveDocs:
http://livedocs.adobe.com/livecycle/8.2/wb_help/000393.html
Thanks Nith
Total Likes
That’s a good job !
Cheers,
Nith
Total Likes
