Has anyone had any luck building the esubmissions_2_0 build? I was able to build the eSubmission.1.0 a few weeks ago with the help of the esm-gettingstarted.pdf, but I can't find the documentation for the 2.0 build. I tried to do the same thing I did with 1.0 but there are some slight differences.
Total Likes
Can you post your errors?
I had a few issues that were fixed and I'm curious if you have the same ones.
Total Likes
there's a known documentation bug in the latest esm_gettingstarted.pdf (Feb 2010) (If you have a jboss turnkey install) regarding the two J2EE jar files necessary to build. I had to specifically add in the jar files needed (servlet-api.jar and clientall) to get it to work. It was fine after that.
Total Likes
John,
Where/what did you add those jar files to?
Thanks.
Total Likes
I made the change in C:\Adobe\sa\esm_2_0\solution_templates\review_portal\build.xml
changes highlighted.. this fixed it for me.
Total Likes
Thanks John. I ran into that as well and Amit helped figure it out in a slightly different way. Your approach helps as well.
I wonder if the other poster had the same issue.
Total Likes
