Hello,
I try to flatten a dynamic form in a process but I don't have the PDF-Generator or the Output service. I have licensed the ReaderExentions and ContentService.
Is there any possibilty to flatten a form to "normal" pdf?
Regards
Christoph
Total Likes
I think only transformPDF activity can do this. So you might require Output service for this feature.
Nith
Total Likes
Output Service is required to truly flatten. You can do some tricks with other services to make that fields on a PDF non interactive, but the PDF still think its an interactive form and appears like it.
Total Likes
If the form is a Static XDP based form (when you create the template you mark it as static or dynamic) then you can flatten it using Assembler. If the form is dyanamic, however; Assembler will try to call Output.
Total Likes
