Locked
Error #2032: Stream Error. URL: http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/osmf_4.0.0.1257
Dec 05, 2009 Dec 05, 2009
I just downloaded the zip nightly build and rebuilt all my projects/libraries.  Now I'm getting this error.  How do i fix this?
Developers
52.4K
I'm using a Mac, 10.5.8, Safari 3.2.3, Flex Builder 3, Flash Player 10, and it is tracing out this:
Error #2032: Stream Error. URL: http://localhost:3000/bin-debug/textLayout_1.0.0.565.swf
Failed to load RSL textLayout_1.0.0.565.swf
Failing over to RSL http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/textLayout_1.0.0.565.swf
Warning: Ignoring 'secure' attribute in policy file from http://fpdownload.adobe.com/pub/swz/crossdomain.xml.  The 'secure' attribute is only permitted in HTTPS and socket policy files.  See http://www.adobe.com/go/strict_policy_files for details.
[SWF] /bin-debug/Flex4Test.swf - 317,860 bytes after decompression
Error #2032: Stream Error. URL: http://localhost:3000/bin-debug/osmf_4.0.0.12575.swf
Failed to load RSL osmf_4.0.0.12575.swf
Failing over to RSL http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/osmf_4.0.0.12575.swf
Error #2032: Stream Error. URL: http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/osmf_4.0.0.12575.swf
Dec 07, 2009 Dec 07, 2009
I had to comment that osmf one out:
<?xml version="1.0"?>
<flex-config>
    <!-- TextLayout SWC -->
    <runtime-shared-library-path append="true">
<path-element>/Applications/Adobe Flex Builder 3/sdks/flex_sdk_4_12575/frameworks/libs/textLayout.swc</path-element>
<rsl-url>textLayout_1.0.0.565.swf</rsl-url>
<policy-file-url></policy-file-url>
<rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/textLayout_1.0.0.565.swf</rsl-url>
<policy-file-url>http://fpdownload.adobe.com/pub/swz/crossdomain.xml</policy-file-url>
</runtime-shared-library-path>
    <!-- OSMF SWC
<path-element>/Applications/Adobe Flex Builder 3/sdks/flex_sdk_4_12575/frameworks/libs/osmf.swc</path-element>
<rsl-url>osmf_4.0.0.12575.swf</rsl-url>
<rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/osmf_4.0.0.12575.swf</rsl-url>
</runtime-shared-library-path>-->
    <!-- Framework SWC -->
<path-element>/Applications/Adobe Flex Builder 3/sdks/flex_sdk_4_12575/frameworks/libs/framework.swc</path-element>
<rsl-url>framework_4.0.0.12575.swf</rsl-url>
<rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/framework_4.0.0.12575.swf</rsl-url>
    <!-- Spark SWC -->
<path-element>/Applications/Adobe Flex Builder 3/sdks/flex_sdk_4_12575/frameworks/libs/spark.swc</path-element>
<rsl-url>spark_4.0.0.12575.swf</rsl-url>
<rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/spark_4.0.0.12575.swf</rsl-url>
<!-- RPC SWC -->
<path-element>/Applications/Adobe Flex Builder 3/sdks/flex_sdk_4_12575/frameworks/libs/rpc.swc</path-element>
<rsl-url>rpc_4.0.0.12575.swf</rsl-url>
<rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.0.0.12575/rpc_4.0.0.12575.swf</rsl-url>
</flex-config>
Probably not set up yet.
Guest
Looks like there may be issues with the RSL.  It might be related to 12545.  The build process for OSMF.swc is still undergoing some further changes, but I'll make sure to take a look at this issue really soon.
-Ryan
Dec 17, 2009 Dec 17, 2009
I believe this was fixed in the nightly build 4.0.0.12940.
http://bugs.adobe.com/jira/browse/SDK-24711
Peter
Enthusiast ,
Mar 09, 2011 Mar 09, 2011
Im using
flex_sdk_4.1.0.16076
I've chosen not to use RSLs and Im still getting this URL asked for, my apps are not allowed to access this url due to firewall
If you are not using RSLs then make sure all of you apps and modules have been recompiled without RSLs (-static-rsls=true). I suspect you still have an application or module compiled with RSLs.
-Darrell
May 17, 2011 May 17, 2011
Hi Darrell,
I'm also receiving this error in one of my projects, but adding -static-rsls=true to the additional compiler arguments line causes an error when compiling. When I ignore this and continue compiling and try run the .swf anyway I still get error #2032
Do I have that argument wrong?
Best regards,
Gareth
To removed RSL linkage in Flash Builder, go to the "Flex Build Path" Properties Page, "Library path" Tab, and change the Framework linkage to "Merged into Code".
-Darrell
May 18, 2011 May 18, 2011
Hi Darrell, that works now. Thanks very much!
I have one problem now though - doing that turned my file from 100kb to over 600kb in size, is there another way I can get around without sacrificing file size?
Many thanks,
Gareth
There a couple of ways to reduce your application file size.
1. Use RSLs.
2. Break up your application into modules.
The best gains on application file size can be made when you do both #1 and #2.
-Darrell
