6 Replies Latest reply on Dec 8, 2009 12:15 AM by David_F57
    Record and playback voice in Flex
    The Bruder
      Is that possible to do it from Flex (of course with some kind of server side),
      Any suggestions?
        • 1. Re: Record and playback voice in Flex
          David_F57 Level 5
          What are you trying to achieve ?, maybe I can help if I have an idea what it is you want to do. For instance with media server you have net audio stream recording.
          David.
          • 2. Re: Record and playback voice in Flex
            The Bruder Level 1
            Hi David,
            I'm need to record from the microphone and be able to play in.
            In fact i found something:
            http://coenraets.org/blog/2009/11/voice-notes-record-voice-notes-and-persist-them-in-sqlit e-with-air-2/
            I'm trying to figure if i can do in from a web flex client.
            • 3. Re: Record and playback voice in Flex
              David_F57 Level 5
              I looked at the example and modified it for flex(i'm all setup with fp 10.1 development). Everything compiled ok the settings showed the mic was active and there was sound but it didn't seem that flex was accepting the data.
              Anyway have done a bit of reading and it seems that although the flex app compiles cleanly, it ignores the microphone eventlisteners as these mean't to only work with desktop apps.
              David.
              • 4. Re: Record and playback voice in Flex
                David_F57 Level 5
                finally got the mic working in the browser, with a little help from one of the FP10.1 prerelease guys, Now its a matter of getting mic settings right to record clear sound.
                <?xml version="1.0" encoding="utf-8"?>
                <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/halo" width="772" height="561">
                <fx:Script>
                <![CDATA[
                private var mic:Microphone;
                private var rec:ByteArray;
                private var snd:Sound;
                protected function recBtn_clickHandler(event:MouseEvent):void
                if (event.currentTarget.selected == true)
                event.currentTarget.label = "Stop";
                rec=new ByteArray();
                mic = Microphone.getMicrophone();
                mic.rate=44;
                mic.addEventListener(SampleDataEvent.SAMPLE_DATA, getMicAudio);
                ply_Btn.enabled=false;
                else
                mic.removeEventListener(SampleDataEvent.SAMPLE_DATA, getMicAudio);
                event.currentTarget.label = "Record";
                ply_Btn.enabled=true;
                protected function plyBtn_clickHandler(event:MouseEvent):void
                rec.position = 0;
                snd = new Sound();
                snd.addEventListener(SampleDataEvent.SAMPLE_DATA, playRecorded);
                var channel:SoundChannel;
                channel = snd.play();
                channel.addEventListener(Event.SOUND_COMPLETE, stopPlayback);
                else
                event.currentTarget.label = "Play";
                snd.close();
                private function getMicAudio(e:SampleDataEvent): void
                rec.writeBytes(e.data);
                lbl.text = String(rec.length);
                private function playRecorded(e:SampleDataEvent): void
                if (!rec.bytesAvailable > 0)
                return;
                var length:int = 8192;
                for (var i:int = 0; i < length; i++)
                var sample:Number = 0;
                if (rec.bytesAvailable > 0) sample = rec.readFloat();
                e.data.writeFloat(sample);
                private function stopPlayback(e:Event): void
                ply_Btn.selected=false;
                ply_Btn.label="play";
                </fx:Script>
                <s:ToggleButton id="rec_Btn" x="20" y="25" width="80" label="Record" click="recBtn_clickHandler(event)"/>
                <s:ToggleButton id="ply_Btn" x="20" y="60" width="80" label="Play" click="plyBtn_clickHandler(event)" enabled="false"/>
                <s:Label x="121" y="29" text="0" id="lbl"/>
                </s:Application>
                • 5. Re: Record and playback voice in Flex
                  The Bruder Level 1
                  Hi David,
                  Thanks for the help!
                  I tried your code and still can't hear my record.
                  I see that when i start the record i don't get to the 'getMicAudio' callback
                  at all.
                  Maybe i have a configuration problems or i am working with the wrong SDK?
                  (I am working with sdk 4.0.0.10485, and as for the sound, i am using the
                  windows test recorder and it works).
                  What am i missing?
                  • 6. Re: Record and playback voice in Flex
                    David_F57 Level 5
                    Firstly I can't get this to work in chrome or safari, although I have flashplayer 10.1 installed they don't recognise it, (chrome works in debug mode but the plugins I have are under pre-release so I can't help you there sorry).
                    It works fine in IE8, but you need to do 2 things I allow the site if its remote and 2 switch your microphone on. (right click on the flashfile and adjust the flashplayer settings).
                    http://ezflex.net/recorder/
                    try this if it doesn't work sign in here and i'll show you it working
                    https://connectnow.acrobat.com/davidf57/testdev
                    David.
