I am using Captivate 4 on a Windows XP machine. Audio was working fine in Captivate and in all published projects until several days ago. Now it has quit working in published projects (preview in browser and published projects) although it still works to preview slides within Captivate. I have read everything I can find on the forums on these issues and have tried the following suggestions:
1. Removing the Captivate folder from my Documents and Settings directory so that the default audio settings were restored.
2. Downloading the audio patch update through Help>updates
3. Installing the NSAudio.dll patch file
None of these things has made any difference. Desperately looking for a solution now... Anyone have any ideas what else I should try?
Thanks very much in advance,
Whitney
Hi Whitney,
Perhaps a stupid question, but it happens a lot of time for me personally that I overlook the most obvious. Could you check the Preferences, Project, Publish settings if the option 'Include audio' is activated?
Lilybiri
Lilybiri:
Always good to double check the obvious, and yes, I did check into that in all projects and include audio is checked.
Whitney
Also wanted to mention that I checked to make sure the mute audio button was not selected in the project...
Whitney
Hi Whitney,
It would seem to me that your source Captivate project file might have become corrupted. I would suggest that you try opening a new instance of Adobe Captivate, creating a new project file at the same dimensions; selecting all the slides in your original .cp file and try copying and pasting these into your new project. Having done that, try publishing the new file and see if that solves the problem.
If not, then try exporting all of the audio files - you can do that via the Library panel - and play each of the WAV or MP3's in something like Media Player to make sure that the audio hasn't become damaged in one of your audio files.
HTH
Best - Mark
<a href="http://macrofireball.blogspot.com/"><strong>Visit the macrofireball blog</strong></a>
Mark:
Thanks very much for the ideas. I had thought that might be a possibility so I did export the audio already and check it in another program and it works fine. I have also created 3 brand new captivate projects and imported different audio into each one and the same thing is happening in all of them. It seems like it must be something in the Publish settings that is doing this, but I can't figure out what it is...
Is it something that maybe I should uninstall Captivate for and then re-install to return original settings?
Thanks again,
Whitney
Hi Whitney
If you want to zip up the small test where things aren't working for you and upload as an attachment, I'll be happy to download and test on my end to see if I get the same behavior.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Rick:
Thanks so much for your offer. I think I finally found out what was going on. I ran a virus and spyware scan, found a few critters on there, then rebooted and everything is now working. Perhapst this is what was doing it for some reason...?
Whitney
LOL, glad you got it sorted!
I suppose it could have really been anything. Perhaps you just needed to reboot. Perhaps it was related to critters. I'd personally be surprised if that were it.
My personal vote goes for either phase of the moon or sunspots...
Cheers... Rick
Yes, thinking back on it I may not have rebooted after I installed the NSAudio.dll file. I may have just gone back in and tried all these things over again. Could that have been the issue?
Whitney
Hi Whitney,
Yes, if the dll was not registered correctly this would explain why the audio was missing. I had an incident last year where I couldn't hear audio on preview and nor could I import audio. Even when we tried to manually register the dll's they stiill wouldn't take. In the end a member of the Adobe support team manually rebuilt the registry on my computer remotely using an Adobe Acrobat Connect Professional meeting room.
Man it was fun watching Adobe tweak my computer registry 🙂
Best - Mark
