2
Set Hand Tool as default?
Dec 07, 2009 Dec 07, 2009
Hello,
I would like to set the default tool in Adobe Reader to be the Hand tool instead of the Select tool. How can I do this? Every time I open a new document I need to reselect the hand tool, which is extremely tedious.
83.2K
correct answers 2 Correct answers
Adobe Employee , Sep 09, 2022 Sep 09, 2022
Hi All
This issue is fixed with the new release 22.2.20212 now available. Please update the application from the help menu > check for updates and reboot the computer once.
For more information about the new release please go through the help page https://www.adobe.com/devnet-docs/acrobatetk/tools/ReleaseNotesDC/index.html
Regards
Amal
Adobe Employee , Sep 22, 2022 Sep 22, 2022
Hi mschwarze,
Sorry for the inconvience caused. We are showing Select Tool as default,  To change it to hand tool we can easily do it through just by selecting Hand tool and to get Hand tool selected always you can select Touch Mode Always under Preferences --> General.
Please let me know if this is not the issue to fix it asap.
Thanks & Regards
Gaurav
Mar 23, 2011 Mar 23, 2011
I also would like to know this answer? Thanks
To set Adobe Reader X to open with the hand tool active what I did was:
Open Adobe Reader X
Right Click on the toolbar
Mouse Down to "Select and Zoom"
Click on the Hand Tool
The Hand Tool appears on the Tool Bar
Close Adobe Reader X
The next time you open the Reader the Hand Tool is selected.
The Reader seems to open with whatever tool that was selected when it was last closed.
It's a pitty that the Installer does not check what tool the previous version used beore it replaces it
Hope this helps.
Dave
Apr 27, 2013 Apr 27, 2013
I have the same problem. I already have the Hand Tool button in my toolbar. I have to click on it every time I open Reader X, because it never defaults to the Hand Tool. Any other thoughts?
Here is what I found.... Go to:
Edit/Preferences/Accessibility
In the section marked "Other Accessibility Options", de-select the check box labeled "Always display the keyboard selection cursor"
This fixed it for me.
Hope this helps.
Mar 08, 2021 Mar 08, 2021
You are such a genius.
Thanks so much.
Adobe Employee ,
Hi mschwarze,
Thanks & Regards
Gaurav
Sep 14, 2013 Sep 14, 2013
I tried all these suggestions to no avail.  I did try something else that worked.  Go to Edit/Preferences/General and check "Make hand tool select text & images".  This defaults to the Hand tool which changes to the Select tool temporarily when you mouse over text or images.  As long as the cursor isn't over text, you're using the hand tool and can use arrow keys to change pages.
Sep 16, 2016 Sep 16, 2016
Better late than never. I found this option to work:
Look under Preferences – Accessibility and uncheck “Always display the keyboard selection cursor”. Then select the Hand Tool. Then close the program. So far the pan (hand) tool remains the default.
Cheers
(Running Adobe Acrobat X on Win 10)
Oct 31, 2016 Oct 31, 2016
This helped!!
Mar 12, 2020 Mar 12, 2020
Thank you thank you thank you! Driving me crazy... now fixed 🙂
Oct 20, 2021 Oct 20, 2021
This was driving me crazy!  I finally discovered that when in "Preferences" I was not seeing the entire window.  I had to awkwardly move the window and scroll to the bottom to get to the "OK" button after making changes.  In the end, Preference/General then set "Touch Mode" to Always, then get to the bottom of the window and select OK.  Then the hand tool is default when opening documents....Hope this helps.
Nov 11, 2021 Nov 11, 2021
That is THE solution to the problem.  Thank you very much for discovering that.
Nov 25, 2021 Nov 25, 2021
This worked. Thank you so much.
Steve Sander
Dec 07, 2021 Dec 07, 2021
Thank you! Out of all of the suggestions here, this is the only one that has worked.
Dec 12, 2021 Dec 12, 2021
Yes, this works for me too! Thanks a lot.
Dec 29, 2021 Dec 29, 2021
감사합니다!! 이 방법으로 해결 됐습니다^^
Thank you VERYMUCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jan 25, 2022 Jan 25, 2022
Jan 29, 2022 Jan 29, 2022
This is it! Thanks you!
Feb 01, 2023 Feb 01, 2023
Thank you!!!!!!
Mar 23, 2023 Mar 23, 2023
It finally works! Thank you.
Jun 13, 2023 Jun 13, 2023
This worked. Thnak you!!!
Nov 03, 2021 Nov 03, 2021
I have the same issue with Adobe Acrobat Pro.
This worked with me:
1. Close all apps and documents
2. Open a PDF using Adobe Acrobat ... in principle, the Select tool is active by default right?
3. Just right click somewhere in the middle of the page and select the Hand tool (do not use the toolbars)
4. Close Adobe Acrobat
Now try to open a PDF using Adobe Acrobat again and in principle the Hand tool should be active by default.
Aug 15, 2022 Aug 15, 2022
I need to necro this unfortunately. A very recent update to Reader has nullified these methods both on my work and personal computers. Anyone else have a solution?
I have the same problem. All of the above solutions, as well as on many other solutions on other forum threads, have been cancelled as of the latest update. There needs to be an easily accessed button to make the Hand Tool default in the future. This appears to be a reoccuring problem that Adobe won't make go away.
