I'm new to Coldfusion and I've never really used regular expressions before. How would I write a ColdFusion function (or just a conditional statement) to check if a form variable is a match for an IP network (44.42.94.0/18)?
I'm just basically looking to see if the backslash "/" character is in the string.
The simplest method for this would be <cfif find(ipstring,"/") GT 0>
A regex expression that might do what you want, completely untested would be ([0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}\[0-9]{1,???} I'm not sure how many digits you want to allow after the slash. Replace the question marks with that number.
I think using find() is a better solution that trying to concoct a regex for this, but... you might want to check the order of parameters for find()...
http://livedocs.adobe.com/coldfusion/8/htmldocs/functions_e-g_21.html#5177400
Adam
It is always good to check the documentation.
But I do find it a bit annoying that the ColdFusion string functions seem to be some of the most inconsitant in what order the comon paramters come.
There are actually plenty of well-developed regular expression strings available on the Internet, which you can simply "copy and use." You don't have to spend too much time figuring-out the correct pattern of chicken scratches.
It's not quite as convenient as saying "use Regexp::Common::URL;" but one cannot have everything in "less-enlightened" languages like CF...
You do need to understand them, however. When you look at the string given in a previous reply, you do need to understand the meaning of all those symbols, and you need to practice the art of being able to cook them up extemporaneously.
