1. Re: How to move slideshow from one project to another?
Mylenium Dec 6, 2009 4:21 AM (in response to h2ofun)I'm not sure I follow. If you are in CS4, all you need to do is to open your project, save it under a different name and set its authoring mode to BluRay. does that not solve the problems on all ends?
Mylenium
2. Re: How to move slideshow from one project to another?
h2ofun Dec 6, 2009 6:02 AM (in response to Mylenium)I do not believe so. For my SD project, I exported my streams as DVD m2v files. For the HD project, I exported the steams as h.264 m4v files
at 1920X1080.
Now, for the menus, all I did was copy the menu folder from my SD project into my encore HD project. I then went and did import as menu, pointed to the files in this menu folder, and this imported all the custom menus I had made. Just changed them from 4:3 to 16:9.
So, I can see all the slideshow pictures in the SD project also in a folder. So, I have copied this folder into my HD project. But, I do not seem to be able to find a way to import like I was able to do with the menu's. There has to be a way, I hope, since I lost the original pictures.
What I am finding is as I take my HD SD projects and convert them to HD projects, being able to import these common assets is a huge need.
Any other ideas?
Dave
3. Re: How to move slideshow from one project to another?
h2ofun Dec 8, 2009 4:42 PM (in response to h2ofun)So, no one has made this work?
Dave
