Hi there Jusnatters
I'm not claiming to know exactly why things aren't publishing
for you, but there is one little thing in the back of my mind that
I seem to recall may adversely affect the process.
In Windows, you have the ability to view your files in
different ways when you are using Windows Explorer. For example, if
you click the View menu, you may choose between:
* Thumbnails
* Tiles
* Icons
* List
* Details
If you were to choose Thumbnails view, Windows may have
created a file named thumbs.db. This file is flagged as a system
file by the Windows file system. I believe it's possible that if
this file exists, it could possibly be a reason the publish is
failing. So you may need to search the folders for the existence of
the file and banish it.
To do this will require a bit of work. First, you need to
ensure you can actually see it. To do that, from Windows Explorer,
click Tools > Folder Options... > View tab and make the
following changes:
Enable "Do not cache thumbnails"
Enable "Show hidden files and folders"
Disable "Hide extensions for known file types"
Disable "Hide protected operating system files (Recommended)"
Once you have made those changes, click OK to dismiss the
dialog.
Now scan the files and folders for the existence of files
named "thumbs.db". Delete any you find. After you are certain they
are all gone, try publishing again.
As I said earlier, there are probably other reasons the
publishing process could fail. This is but one. But it's worth a
try.
Please try that and report back with how it worked out.
Sincerely... Rick
