1 Reply Latest reply: Dec 11, 2009 7:54 AM by AdobeScripts RSS
    PDF Export fails because of "bad" TIF files
    soom1976 Community Member
      I'm having this problem with InDesign CS3 on MacBook Pro, OS 10.5
      PDF export fails occasionally, becasue of some "bad" TIF files. The weird part is that those files are completely good TIF files, which are perfectly readable by any other program! After I resave the supposedly bad file again, it helps, and the PDF export works fine. BUT - imagine me working with a project with 800 images?!! Thanks to some good scripting and forum people, I have found a way to locate the bad images quite fast by using a script that exports each page as a separate PDF, then at least I know at which page it fails. But it's a hassle to do that every time!
      Last time I found about 60 "bad" files out of 862.
      Why the heck InDesign treats some TIF files as bad? Even if it does, it could at least create a log file, that will tell me at which page the export failed! this could be a real help!
      I've asked this question in Photoshop forums, but one of the employees replied that Photoshop doesn't produce bad files. Well, I'm not sure I can belevie that, but that's what they say.
