If a user points to an area on the screen I want a caption to display (with voiceover) AND an image to display elsewhere on the screen at the same time. Is this possible? Is seems as though, because of the layering of objects on the screen, this cannot be accomplished?
Hi Karin
This is normally where one would consider using a Rollover Slidelet. Basically you roll over one area and a second area is revealed. The second area would then contain the image as well as the caption.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Yes, normally, that is would I do...however, I always have trouble with rollover slidelet is that the audio and video attached to them play prematurely. For example, if the slidelet is on slide a slide midway thru the stack, it "plays" as soon as I start the module. So I've not been using this feature because I cannot seem to get it working the way I want it to...I've had this problem since version 3.
