Show 2 replies
1. Re: How to use color picker or RGB values in the hue-saturation colorize adjustment
Zeno Bokor Dec 12, 2009 12:27 AM (in response to DVDmike)You can add a layer filled with that color and set it to the Color blend mode. Or open the color picker, enter your color using the RGB fields and then memorize the HSL fields and enter them into the Hue/Saturation adjustment
2. Re: How to use color picker or RGB values in the hue-saturation colorize adjustment
DVDmike Dec 12, 2009 8:46 AM (in response to Zeno Bokor)Thanks Zeno. Creating a layer with the color and using the blend mode worked fine. But as I stated in the original post, using the H/S/B (there is no HSL) values from the color picker does not work when you place them into the H/S/L values in the hue-adjustment layer with (or without) the colorize box checked. But your first suggestion worked like a charm. Thank you.
