any idea?
if i change the source to go down the code tree to say
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/gariff"
then all is fine
but all of the following give the same error
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/"
-s "D:/wrk_gapp-i17/gariffCode/src/"
is it the amount of files?
any source that goes deeper is fine;
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/gariff/views"
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/library"
etc
as you can see ive tried uping the memory (same what ever value i use)
using latest version as far as i know
$ java -Xmx1024 -jar "A:/_tools/flexPMD/flex-pmd-command-line-1.0.jar" -s "D:/wrk_gapp-i17/gariffCode/" -o "D:/wrk_gapp-i17/gariffCode/_pmdOut/all_flex/" -r "A:/_tools/flexPMD/all_flex.xml"
12-Dec-2009 21:34:09 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine loadRuleset
INFO: Ruleset: A:\_tools\flexPMD\all_flex.xml
INFO: Rules number in the ruleSet: 82
Exception in thread "main" java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.set(Unknown Source)
at com.adobe.ac.pmd.files.impl.MxmlFile.copyScriptLinesKeepingOriginalLineIndices(MxmlFile.java:131)
at com.adobe.ac.pmd.files.impl.MxmlFile.extractScriptBlock(MxmlFile.java:162)
at com.adobe.ac.pmd.files.impl.MxmlFile.<init>(MxmlFile.java:55)
at com.adobe.ac.pmd.files.impl.FileUtils.create(FileUtils.java:83)
at com.adobe.ac.pmd.files.impl.FileUtils.computeFilesList(FileUtils.java:58)
at com.adobe.ac.pmd.FlexPmdViolations.computeFiles(FlexPmdViolations.java:131)
at com.adobe.ac.pmd.FlexPmdViolations.computeViolations(FlexPmdViolations.java:94)
at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.computeViolations(AbstractFlexPmdEngine.java:156)
at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.executeReport(AbstractFlexPmdEngine.java:138)
at com.adobe.ac.pmd.commandline.FlexPMD.startFlexPMD(FlexPMD.java:115)
at com.adobe.ac.pmd.commandline.FlexPMD.main(FlexPMD.java:69)
You have somewhere in your code base, a MXML file which leads to this exception. It would great if you could try to identify this one.
You would then be able to add to the test suite to avoid regressions.
Xavier
From your stacktrace, it is not related to the size of the project.
Can you open a bug in JIRA with the stacktrace, please?
Xavier
Xavier
Hi again
now I know where to start looking I'm positive i can track this one down for yo9u this evening.
i'll get back to you later
cheers
Great Glenn !
